BEWARE! LONG WINDED POST! SCROLL TO THE BOTTOM TO GET TO THE POINT!!!! LOL
so I'm in the process of planning out my I7 Build, and I figured I'm probably going to have to start from the ground up, but to give you guys an idea of what I'm looking for and why I might seem a bit ridiculous, my last build went like this:
original purchases:
-thermaltake soprano case
-corsair 520HX
-4gb Muskin ddr2 1066
-500gb wd hd
-Asus P5Q-LE
-Intel Q6600
-Sapphire 4850 (reference card)
-20" samsung 206bw
-OCZ vendetta 2
Now, after I finished that build and started using/overclocking, within about 2 months this is what my system changed to:
-Thermaltake soprano
-Asus Maximus formula 2 motherboard
-corsair 620HX
-4 gb Mushkin ddr2 1066
-500gb wd hd
-intel q6600
-Sapphire 4850 (Reference card)
-zalmaan gpu cooler (9500? I think thats the number)
-Palit 4850 sonic edition
-NZXT dual bay fan controller
-2x black ice gt 120 rads
-apogee gtz block
-swiftech northbridge block
-3.5" bay resovior
-swiftech mcr355 pump
-20" samsung 206BW
(6 months later) Now my system consists of:
-Coolermaster Cosmos S
-corsair 620HX
-500gb wd hd
-intel q6600
-Scythe Kaze 5.25" bay fan controller
-1x swiftech 320 QP rad
-apogee gtz block
-swiftech micro res v1
-26" samsung 2693HX
SO in a really long winded way, what I'm trying to say is: I WENT CHEAP AT FIRST AND REGRETED IT. I hated my motherboard, I couldnt overclock due to cheap motherboard and heat issues. my case was really small for incorporating a watercooling loop, so I ended up paying almost double to get what i wanted in the end.
So I'd like to hear what people think I should use/keep for my build, what they recommend etc.
So far the only things that Im set on getting are:
-intel I7 920
-Corsair 1000HX
which leaves me needing:
-gpu - use the 2 4850s? or get new ones?
-motherboard: recommendations?
-ram: DDR3 recommendations?
I dont want to break the bank on this upgrade, but I will pay more to get a better product that will leave me with options in the future and is more dependable. (ie I dont care to have a $1000 cpu, or a nvidia 295, but I'll fork out $400 for a mobo if it means I can push my cpu 1/2 ghz farther)
