Old May 19, 2009, 02:08 PM
Default Old Mobo Tray fitting question
So I have an old mobo tray in an old case that I'm modding.
Seems there is no need for stand offs for the mobo to sit on...but I don't want to just screw the mobo directly on the metal .... what can I do?
Old May 19, 2009, 02:19 PM
sswilson's Avatar
The standoffs are pre-punched so it's designed for you to screw the motherboard directly to the tray.
Old May 19, 2009, 02:22 PM
Won't the motherboard making direct contact with the tray be an issue?
Old May 19, 2009, 02:23 PM
Look at the back of the board you'll see around the holes small metal bumps.
This is to protect the board but only if you don't over tighten the board.
Old May 19, 2009, 02:26 PM
Alright, excellent guys!
I feel like such a noob sometimes!
Old May 19, 2009, 02:36 PM
SugarJ's Avatar
You were going to put metal standoffs in a metal tray, there's no reason not to screw it directly to the tray as long as no components directly touch the tray.
Wood motherboard tray?? Saibot Cases 16 May 20, 2009 08:06 AM
Inverted Motherboard tray Phobia Cases 7 March 23, 2009 06:42 PM
ram/mobo question Jim RAM 1 March 8, 2009 09:11 AM
Question about installed memory on x58 mobo. Answerzz RAM 8 February 14, 2009 10:39 PM
If I update drivers or install the ATI tool tray.... Canadianguy Video Cards 7 July 28, 2007 12:34 PM
