Old May 13, 2009, 05:40 AM
I checked out the board you suggested Rapmaster and i did view that one before when trying to decide it is $129.00 after rebate. The reason i went P5Q as i said before was even though crossfire board it was $125 and free shipping included for my order so apple to apple orange to orange comparison or should i say mobo to mobo :) i thought P5Q was an on par to the one you mentioned Gigabyte EP45-UD3R but i'd save on shipping.
Old May 13, 2009, 05:55 AM
I looked at the CM590 case thanks --- will it fit the gtx 260 gpu?
Old May 13, 2009, 05:59 AM
Soultribunal's Avatar
I think either the Gigabyte or the Asus board are very good offerings to be honest.
Which everyone suits you best would do just fine.
Regards,
ST
www.realhardwarereviews.com
Old May 13, 2009, 06:01 AM
Thanks Matsta for psu info . In regards to AMD nice suggestion but i think i'm leaning more to staying Intel.
In regards to not moving on my P4 for awhile this is correct i'll probably will hang out with this new build for a little while also LOL.
Old May 13, 2009, 06:27 AM
Thanks ST i'll probably will go ASUS as the free shipping for full order deal from NCIX
Looks like so far boys and girls ladies and gents it will be:
Intel Core 2 Duo E8400
ASUS P5Q Pro ATX LGA775 P45
EVGA E-GEFORCE GTX 260 Core 216 SC 55NM 626MHZ 896MB 2.1GHZ
Coolermaster CM 590 Case
G.SKILL F2-8500CL5D-4GBPK PC2-8500 4GB 2X2GB DDR2-1066
Corsair VX550W Power Supply
Western Digital Caviar Black 640GB 7200RPM 32MB Dual Proc
Old May 13, 2009, 06:41 AM
rapmaster's Avatar
also, buy some fans since the 590 come with only 2
Quando omni flunkus moritati
Old May 13, 2009, 07:46 AM
Some extra Fans i'll add to my grocery list for PC build pie. Just regular low end fans or is there a big difference. I would imagine ones that are quiet and stable. Shouldn't be that much of a biggie.
Old May 13, 2009, 07:58 AM
New build in the WORKS:
I adjusted the prices and price matched by dropping the psu for the Cosair 550w and the case to a CM590 i'm now in @ a price of $895 for the above. that is rebates included.
  #19 (permalink)
Old May 13, 2009, 08:35 AM
That sir, looks very solid for the Budget, I'd stick with it and make it happen.
Regards,
ST
  #20 (permalink)
Old May 13, 2009, 09:34 AM
Good to hear ST thanks for the vote of confidence I hope to have this done before Mays out.
Now how to I sneak this past my wife hmmmm!!! :)
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
