Build for a friend 1. What YOUR PC will be used for. That means what types of tasks you'll be performing. Gaming mostly, but also the basics such as surfing, listening to music and watching videos. 2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread 700 CAN 3. What country YOU will be buying YOUR parts from. Canada 4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture. whatever is cheaper 5. If YOU intend on using any of YOUR current parts, and if so, what those parts are. none 6. IF YOU have searched and/or read similar threads. yes, a few 7. IF YOU plan on overclocking or run the system at default speeds. default speeds 8. WHEN do you plan to build it? within this month(May) so A friend of mine asked me to help him build a new PC. so far I've got the following. AMD Athlon X2 7750 Black Edition Gigabyte GA-MA770 UD3 ATX AM2 /AM3 Sapphire Radeon HD 4830 G.SKILL F2-6400CL5D-4GBPQ PC2 6400 4GB LG GH22NS30 Black DVD RW Samsung 250GB HDD Antec Sonata 3 w/500W PSU ATI 4830 Now he just ordered this stuff, but I decided to post anyway so he has a chance to cancel and change his order. I just would like to confirm all these parts are compatible. |
NCIX.com - Buy AMD Power of Black Bundle Deal Athlon X2 7850 2.8GHZ & Gigabyte GA-MA770-UD3 DDR2 Motherboard - 7850-GA-MA770-UD3 In Canada. You may want to consider this deal, you get a better processor at an better price and get a hd4770, it perform better and consomme less energy. |
over all good picks. AMD is the king of value ;) |
i see 2 4830's in your post. typo? or is your friend gonna do crossfire with that 770g board ? |
hmm, never heard of the 4770? I'm a newbie myself, I've always thought it goes 4830>4850>4870>4890? |
4770 came out about a week or two ago. It uses GDDR5 and performs roughly on par with the 4850, but less noise, heat and energy consumption for about 130 Canadian. |
| All times are GMT -7. The time now is 03:09 AM. |
