Old May 6, 2009, 03:20 PM
Amn Amn is offline
Default Advice on gaming build
Hey, just wanted to know whether you guys had anything to say before I get this setup. Any advice would be appreciated. I'm new to all this, so I'm just looking for some guidance.
Case: Antec P182
Mobo: ASUS P6T Deluxe V2
CPU: Intel Core i7 920
Cooling: Noctua NHU12P SE1366
GPU: GeForce GTX 275
Memory: Corsair XMS3 6GB DDR3 3X2GB
PSU: Corsair TX750W 750W (for future flexibility)
HD: Western Digital Caviar 640GB x 2
Old May 6, 2009, 03:46 PM
SugarJ's Avatar
Nice parts. I'd suggest you get the Black model of the 640gb drives, they are faster.
Old May 6, 2009, 03:50 PM
TimTheEnchanter's Avatar
Killer build. If you want a case that is more flashy may i suggest the HAF 932.
What monitor do you (or will you) have?
Old May 6, 2009, 03:57 PM
Amn Amn is offline
Thanks for the replies. I'll look into the Caviar Black.
I'm going to be using a Samsung T240 for the next little while. Are there any major differences (aside from looks) between the P182 and the HAF 932?
Old May 6, 2009, 04:00 PM
rjbarker's Avatar
Case: Antec P182
Dig deeper and try and get a GTX285
Bump up your PSU to 850W (ensure adequate headroom should you get another 285)
Go with the Blacks as mentioned
Ensure you get 1600 Mhz RAM (if you plan on OC'ing)
Firestrike Extreme: 21.452
MARK 11: 32.530
Old May 6, 2009, 04:15 PM
Amn Amn is offline
Is there a big difference in performance between the 275 and the 285?
I was also probably not going to get a sound card. Is that a bad idea?
Old May 6, 2009, 05:06 PM
rjbarker's Avatar
Yep - especially noticeable if your running higher Resolutuions
I personally find onboard Audio suitable for my needs
MARK 11: 32.530
Old May 6, 2009, 05:18 PM
rapmaster's Avatar
Nvidia GeForce GTX 275 896MB Review
here a review of the gtx275 with gtx285 benchmark
Imo, I don't think is worth the 100$+ premium but you will notice the difference in higher resolution
Quando omni flunkus moritati
Old May 6, 2009, 07:20 PM
rjbarker's Avatar
thats your opinion......imo its worth it!
MARK 11: 32.530
Old May 6, 2009, 07:50 PM
rapmaster's Avatar
well, for not even 10% of performance boost, you have to play an 33% premium, that's not good in my opinion, but I'm cheap.
New i7 Gaming Build Wheezy New Builds 14 March 14, 2010 09:51 AM
New Gaming Build? LegendofJubei New Builds 3 September 7, 2008 11:14 PM
New Gaming build Baccano New Builds 20 July 2, 2008 08:20 PM
New gaming build Tonguey New Builds 2 June 29, 2008 10:07 AM
