Old May 1, 2009, 11:05 PM
Default using TRUE120 LGA775 Backplate with P6T?
anyone is using the TRUE120 LGA775 Backplate with his ASUS P6T? the board has both mounting holes but I don't know if the true120 775 backplate will fit fine or I still need to buy the 1366 true120 backplate
Old May 1, 2009, 11:22 PM
Jake_HT's Avatar
The holes for socket 775 are 72mm x 72mm
The holes for socket 1366 are 80mm x 80mm.
So it won't work.
EDIT: What? It has both holes? Nevermind then... I said nothing..
http://jakeht.deviantart.com/
Old May 1, 2009, 11:34 PM
the P6T has both mounting holes:
Old May 1, 2009, 11:37 PM
Jake_HT's Avatar
Yeah I see that now.. weird!
Not sure if it will work or not.. It'll be MIGHTY close if it does...
[WTB] Backplate (local) DenisS Buy/Sell & Trade 2 September 23, 2009 08:57 AM
Backplate question DenisS Air Cooling 4 April 5, 2009 09:06 PM
What is a good backplate compatable heatsink? Peppaaro Air Cooling 11 February 25, 2009 08:08 PM
thermalright backplate owners Zippoh Air Cooling 3 December 15, 2008 07:05 PM
Backplate pad pulled off-how to replace it magictorch Troubleshooting 20 July 20, 2008 08:36 PM
