  #21 (permalink)
Old May 2, 2009, 12:30 PM
Looks like you got great pricing for the CPU and RAM.
It will definitely much better in terms of cable management if the DVD is a SATA and not IDE. I was using an old IDE DVD in my system (surplus material) but the flat ribbon is terrible.
[ASUS P6T Deluxe V2] [Intel i7 920 @3.6] [Corsair Dominator 2x3G 1600MHz 8-8-8-24]
[Noctua NH-U12P w/2 x NF-P12] [CoolerMaster HAF932] [BFG GTX285] [2 x Hitachi Deskstar 7K1000.B]
[Vista 64] [Ultra XPro 600]
[coming soon - 2 more Noctua NF-P12-1300, Corsair HX1000 and BFG GTX285 SLI]
  #22 (permalink)
Old May 2, 2009, 12:52 PM
Originally Posted by TimTheEnchanter View Post
If you look at a picture of the CM 690, Sky Chief, i think one of the side fans is meant for the video card area and the other one for the cpu. I was talking, of course, of the cpu area side fan.
Tim, I was referring to the HAF and not the 690. My fault.
If budget allows and OC is in the plan, IMO more fan is better than less.
  #23 (permalink)
Old May 2, 2009, 12:58 PM
kruzn4evr's Avatar
I've built a few rigs with the Noctua in a CM 690 and I can tell you the top side fan will not fit with the Noctua, however with push pull you won't even miss it, the Noctua does fit without the fan and works quite well
In the HAF?...you'll have lots of room!
  #24 (permalink)
Old May 2, 2009, 01:40 PM
I want to OC the whole rig with good temps except for the ram because the i7 is limited to 1600mhz.
I've also decided to get a SATA DVD DL Burner and the most reliable i found was:
DVD BURN: LG GH22NS30 Black DVD+RW / $25.17
Buy LG GH22NS30 Black DVD+RW 22X8X16 DVD-RW 22X6X16 DL 16X/12X 2MB SATA OEM
If I have to make the jump to HAF then I just might.
  #25 (permalink)
Old May 2, 2009, 02:03 PM
Spikemaul's Avatar
By the way i'm pretty sure the Noctua will fit : i have the CM 690 with a Sunbeam core contact, and it fits well. The Sunbeam is 155m and the Noctua (if it's the one i'm thinking about) is 125mm.
However, you may lose one of the side panel fan with such a big heatsink. Unless you do like me and put a fan from outside the case
The Noctua is 158mm. Here's a link to the Noctua spec page.
Noctua.at - sound-optimised premium components "Designed in Austria"!
Cheers!
  #26 (permalink)
Old May 2, 2009, 02:17 PM
What kind of gain am i looking at if I upgrade to the HAF?
  #27 (permalink)
Old May 2, 2009, 10:04 PM
wow great pricing for cpu and ram!
i was all hesitant of buying i7 cuz i thought the mobo +ram + cpu alone would be 1000+
  #28 (permalink)
Old May 3, 2009, 07:15 AM
Not really.
Core i7 920 $340
P6T $300
6GB corsair CL9 1333 ram $100
Total of $740. That's not quite $1000, but it is 3/4 of it.
With a 940 you would hit $1000 very quickly though.
Len Sorensen
  #29 (permalink)
Old May 3, 2009, 07:22 AM
I was going for AMD Phenom II x3 720, and MSI 790GX-G65 abd 4 GB ram, but seeing this i7 built is only $200+ more, I think I'll reconsider.
BTW, this ram in DirectCanada is $86.81:
OCZ Gold OCZ3G1600LV6GK 6GB DDR3 3X2GB DDR3-1600 PC3-12800 CL 8-8-8-24 Triple Channel Memory Kit - DirectCanada
  #30 (permalink)
Old May 3, 2009, 07:27 AM
After my last OCZ ram experience, I am using something else for now.
I had 2GB of OCZ platinum DDR2 in my P5K, and then after a BIOS upgrade the system would no longer start. Apparently OCZ's requirement of higher than standard voltage didn't get along with the ASUS bios's default power on values (which can apparently change with a BIOS upgrade much to my surprise). I now run 6GB of mushkin instead, and give the OCZ to my sister (so she now has 4GB of the OCZ platinum in her system).
Len Sorensen
New i7 $2000 Build - Feedback Appreciated! Strato New Builds 11 April 25, 2009 07:05 PM
New Build Feedback Lelantos New Builds 17 March 16, 2009 09:18 AM
build advice appreciated Hreidmar New Builds 7 October 15, 2008 03:59 PM
Feedback on this build Muad'Dib_53 New Builds 17 August 20, 2008 03:44 PM
$500 Budget gaming rig - feedback appreciated GregH New Builds 10 July 16, 2008 07:04 PM
