Old April 9, 2009, 12:18 AM
Question Power Connectors
Will this Power Supply have the correct power connectors for this card? Newegg.com - XFX HD-489A-ZDFC Radeon HD 4890 1GB 256-bit DDR5 PCI Express 2.0 x16 HDCP Ready Video Card - Desktop Graphics / Video Cards Newegg.com - CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Power Supplies Card needs 2 2X6 Pins, while the Power supply says 4 X 6 +2 Pin. I just need to make sure. Also will the card fit in this case? Newegg.com - XION Onyx XON-303 Black/Blue Steel ATX Mid Tower Computer Case - Computer Cases
Old April 9, 2009, 12:24 AM
Jake_HT's Avatar
That PSU will be fine for that card yes. Can't help you with the case.
http://jakeht.deviantart.com/
Old April 9, 2009, 05:42 AM
aviduser's Avatar
Most mid towers are fine concerning video card space. Check out the comments on your link, I'm sure someone would complain if their vid card didn't fit.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
Old April 9, 2009, 06:13 AM
TopDogZero's Avatar
The only thing that might be a problem is by the looking at the pics of the case there appears it does not have any cutouts for cable management in motherboard tray area. So I would get a modular power supply and only use the cables needed or a different case, off course I could be wrong about the case but the manufacturer web site gives less details than Newegg , so hard to tell.
Old April 9, 2009, 09:56 AM
Realityshift's Avatar
Xion cases are about as plain as they come, no tooless no cable management so you may have some issues with the long cables found on the corsair power supplies unless you dont mind them just laying on the bottom of the case. With a few hours of playing around my TX750s cables fit very nicely into my CM-690 but there was deffinetly swearing going on during that time as the cables are just so damn long.
The Builders Hammer
[FS] All NEW in Stock, memories, connectors, capacitors and more! rdctech Buy/Sell & Trade 12 February 27, 2009 11:46 AM
4 molex connectors on one cable Brian Power Supplies 2 October 8, 2008 07:27 AM
WTB: Pair of G1/4"-3/8" nozzle connectors kruzn4evr Buy/Sell & Trade 6 September 1, 2008 01:09 PM
Seeking MB's that have more than 4 SATA connectors antonin Storage 9 April 1, 2008 11:31 AM
Panel mount connectors for PSU? MacJunky Power Supplies 0 May 18, 2007 05:12 PM
