Old April 4, 2009, 01:43 PM
Perineum's Avatar
Default AM2 motherboard with 2 IDE headers?
Does anyone know of AM2 motherboard with 2 IDE headers? Most only come with 1 header now.
I have someone that wants a newer mb/ram/cpu but would like to reuse all the old parts. I've been looking on NCIX for a while now but it's quite tedious trying to find one by reading all the descriptions.
If someone just happens to know of one, or a few, I'd be much obliged.
Old April 5, 2009, 10:51 PM
aviduser's Avatar
Does he want to overclock it at all? If not you can pick up an older oem board that has ide connectors.
Or he could go with a $30 sata dvd drive and have the hdd running off IDE.
HAF-Full
-Phenom II 940 @ 3.8 ghz
- Sapphire 5870 890/1220
- 4 ghz g.skill
- Corsair tx850w
Old April 6, 2009, 12:02 AM
Perineum's Avatar
They want to keep 2 drives for on the fly burning so it would have been a $60 investment. Thanks for the suggestion but they've just moved on to a board that has one IDE header and will just have both ROMs running off the one.
Old April 6, 2009, 05:10 AM
CanadaRox's Avatar
I'd suggest just spending $20 and purchasing a PCI IDE card. That would probably the quickest and easiest solution.
Project: Black and White
Old April 6, 2009, 04:09 PM
Perineum's Avatar
Good point! You know, sometimes the obvious answer isn't really all that obvious....
Old April 6, 2009, 04:25 PM
If you only have 2 IDE devices you want to control one header should be enough should it not?
Old April 6, 2009, 05:04 PM
Perineum's Avatar
They've got a hard drive in there too, unfortunately.
Old April 8, 2009, 08:23 PM
Killswitch's Avatar
Bingo!!!!!!!!!!! A guy on a local forum in my area was just asking some questions about his build and he has this mobo.
GIGABYTE - Product - Motherboard - Specification - GA-M55plus-S3G (rev. 1.0)
Old April 8, 2009, 10:34 PM
Perineum's Avatar
Hey thanks, that would do the trick.... NCIX doesn't seem to sell that one, however.
New motherboard Jonwall CPU's and Motherboards 5 October 23, 2008 04:37 PM
LF: AGP 8X Motherboard norfolk Buy/Sell & Trade 2 June 17, 2008 09:27 AM
