  #41 (permalink)
Old April 4, 2009, 12:07 PM
somecanadianguy's Avatar
I kept OCCT running for 2hrs
Max temps...
Core1: 59
Core2: 59
Core3: 58
Core4: 57
All cores averaged around 55 degrees.
Idle temp right now is 33.
  #42 (permalink)
Old April 4, 2009, 12:59 PM
bojangles's Avatar
That's much better. You're TRUE is working properly now. Now go have fun! You could test out your memory as well.
  #43 (permalink)
Old April 4, 2009, 02:01 PM
Realityshift's Avatar
Yeah those temps look way better then the 80+ you where getting before.
The Builders Hammer
  #44 (permalink)
Old April 4, 2009, 02:17 PM
element291's Avatar
Indeed! Glad to see he's getting better temps!
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
  #45 (permalink)
Old April 4, 2009, 05:36 PM
Everything seems good now... I'm just playing around.
This machine is awesome
Building my first rig for under $700 Vethrik New Builds 12 February 10, 2009 03:53 PM
Building my first PC. Rolay New Builds 12 October 12, 2008 07:06 AM
Building Phobia Off Topic 9 September 21, 2008 12:29 PM
Building New Rig swiftk1 New Builds 7 August 27, 2008 02:16 PM
Building another rig! Kassela Troubleshooting 5 March 17, 2008 10:14 AM
