<~----> Building right now... need a little help - Page 2 - Hardware Canucks
Old April 3, 2009, 12:26 AM
somecanadianguy's Avatar
I'm still checking things... can't find the problem.
Does the video card have to be in the primary (top) pci-e slot?
It didn't fit there properly.
I sure hope I don't have any dead parts...
Old April 3, 2009, 12:31 AM
Realityshift's Avatar
Yeah its supose to go in the top slot, but that shouldnt stop it from booting up. what happens when you plug it in and turn it on on the back of the PSU? before you even hit the power button on the front of the case.
The Builders Hammer
Old April 3, 2009, 12:32 AM
Nothing... Surge protector light blinks briefly...
Old April 3, 2009, 12:36 AM
no lights inside your case? nothin on the motherboard? try plugging it straight into the wall instead of the surge protector.
The Builders Hammer
Old April 3, 2009, 12:37 AM
Where you carefull putting the CPU into the socket, did you see any bent pins or anything like that?
The Builders Hammer
Old April 3, 2009, 12:44 AM
IT WORKS!
I had the front panel wires wrong...
Thanks again for the help.
Old April 3, 2009, 12:47 AM
Yay congrats, those front pannel wires can be a pain, one of the reasons I like Asus's Qconnectors, makes it a little easier then trying to plug those little connectors into slots while mounted inside your pc.
The Builders Hammer
Old April 3, 2009, 12:54 AM
I hate those Q-Connectors.
I find they are so easy to pull off the board than if you put the wires directly to the board.
  #19 (permalink)
Old April 3, 2009, 01:06 AM
Do I need to run the mobo disk first?
Or Vista?
I'm stuck on "Verifying DMI Pool Data..."
  #20 (permalink)
Old April 3, 2009, 01:12 AM
I got by that once... then rebooted... now it's stuck
Building my first rig for under $700 Vethrik New Builds 12 February 10, 2009 02:53 PM
Building my first PC. Rolay New Builds 12 October 12, 2008 07:06 AM
Building Phobia Off Topic 9 September 21, 2008 12:29 PM
Building New Rig swiftk1 New Builds 7 August 27, 2008 02:16 PM
Building another rig! Kassela Troubleshooting 5 March 17, 2008 10:14 AM
