Old March 31, 2009, 01:42 PM
JD JD is offline
All 22"s are about the same IMO. They all basically use the same TN panels from the same companies. I think there's only a few that are in production.
Any monitor will require tweaking of settings to get the colours decent.
I'd get this one though, since it uses an IPS panel (only 22" I know that does): Dell : Dell UltraSharp 2209WA 22-inch Black Widescreen Flat Panel Monitor : Displays : Home & Home Office
Old March 31, 2009, 09:28 PM
Toronto122's Avatar
TRUST me on this: The BEST upgrade I ever did was buy a BIG monitor. It just brings you INTO the game. Save your money and get a 24", heck, even the Acer 243 is better than a little 22"er! LOL
And if you REALLY save, get a 30! They're simply STUNNING and they'll really put that video card to work!!!
NZXT Rogue Cube Case
Intel i7 920 @ 3.8 w/Scythe Mugen 2
6 gb Patriot Viper 1600mhz low latency
Asus Rampage II GENE Motherboard
2 x Asus GTX 285 in SLI (710/1617/2700)
1 x 1tb WD Black
3 x WD 640AAKS in RAID 0
Enermax 85-1050 PSU
HP 30" 2560x1600, G19, G7, M-Audio Q40 Headset
Old April 1, 2009, 08:08 AM
I saw the Samsung 2253lw, not sure of the difference between the lw and bw, but it's $230 at BestBuy, so I think I'll pick this one up. Thanks.
Old April 1, 2009, 08:26 AM
bojangles's Avatar
There are some 1920x1080 22" monitors out there. They go for a decent price as well.
Old April 1, 2009, 11:29 AM
Realityshift's Avatar
Acer H233H 23IN LCD Widescreen Monitor Black 1920X1080 40000:1 5MS VGA DVI HDMI - DirectCanada
Acer makes decent monitors and at a good price, like its been pointed out most monitors at this size arent going to show much difference but this monitor is atleast the midway between 23 and 24, ive seen one and used one and I liked it, had great color and response when gaming which is all we used it for, and the HDMI and 16:9 resolution was nice, its a little wider then a normal 16:10 monitor.
LG W2242TQ-BF 22IN Widescreen LCD Black 2MS 1680X1050 8000:1 300CD/M2 VGA DVI Tilt Monitor - DirectCanada
Ive always been a fan of LGs monitors, they normally look nice and have great color and contrast. My gf has the 19 inch version of this one and i have the older 20 inch version with less contrast and I deffinetly notice a difference between the 2, hers has way more vibrant colors and the contrast difference is deffinetly there. Sammys are ok but I hate the new ones with that stupid red on black tint.
LG W2442PA-BF 24IN Widescreen LCD Monitor Black 2MS 10000:1 300CDM 1920X1080 1080P HAS Tilt HDMI DVI - DirectCanada
You could throw in $40 more and get a decent 24" LG, again I like these monitors and I believe best buy and futureshop have these on display so you could check them out first.
The Builders Hammer
Old April 1, 2009, 11:39 AM
CTA's Avatar
CTA CTA is offline
Originally Posted by go flames go View Post
dell> samsung imho. unless u got high end sammy
does the dell make their own lcd? or does the dell purchase other company?
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old April 1, 2009, 11:41 AM
Ronin's Avatar
The LW is a 21.6" while the BW is a 22". I heard somewhere that the LW has less backlight bleed. BW is a good monitor for the price.
Old April 1, 2009, 01:04 PM
Thund3rball's Avatar
Dell uses samsung, lg, chimei, etc... same as everyone else. Brand has little to do with quality imo. It all depends on what you're looking for and your budget. The 2209WA from Dell is probably the best 22" I've ever seen, but it is no longer at the one time only price of $220. Otherwise any 22" is pretty much just like the next imo.
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
  #19 (permalink)
Old April 1, 2009, 01:22 PM
CTA's Avatar
CTA CTA is offline
so what kind of lcd does 2209wa use? i mean i would like to know which the high quality (best) lcd is...
  #20 (permalink)
Old April 1, 2009, 01:50 PM
Pretty much all of Dell's IPS panels come from LG (like the 2209wa) and all their PVA panels come from Samsung. But don't be fooled. That doesn't mean every LG panel is IPS and every Sammy is PVA.
Desktop:
See the drop down!
HEATWARE
LF Gaming Monitor Malakei Display Units 1 January 11, 2009 05:36 AM
new monitor djnocide Display Units 3 November 30, 2008 09:38 PM
Samsung Monitor for Gaming slovakftw Display Units 2 November 8, 2008 07:36 AM
New Monitor? s_8ball Display Units 3 April 19, 2008 06:50 AM
tv or monitor ? Jim Display Units 2 April 14, 2007 01:42 AM
