Old March 24, 2009, 01:26 PM
Default Not your typical build
I know most people on here are building rigs for gaming. However, I'm building a rig for my sister and she doesn't game at all. I was hoping to get some advice though and here are the specifics...
The case must be "tiny" according to her so I'm looking at mini cases like the NSK4480. I wanted to give her an HDMI output if she needs to connect to her T.V, so I was looking at the ASUS P5E-VM HDMI. Her budget is only $800 and it has to include a monitor and OS :(. So, I'm not sure what CPU to go for here, but I was thinking of a cheap quad core and the 640GB AAKS drive from WD. Any help you can provide would be REALLY appreciated. Thanks in advance.
Oh, I don't care about the size of the monitor, but I want it to be LCD. Cheapest I've found with a decent resolution is $150.
Watching videos of the kids, storing pics and videos, surfing the net, using MS Office, etc... Nothing intense
Max is $800
I live in Toronto and I can go anywhere: Canada Computers, Infonec, etc...
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
I'd prefer intel since I've only built one AMD rig in the past and I'm more familiar with Intel.
NONE :(
I have, no one has a budget this low that is recent.
Tomorrow - If possible.
INTEL Conroe E6700
EVGA NVIDIA 680i Rev A1
OCZ 4GB DDR2 PC2-8500 Platinum Revision 2
ATI Radeon 4890
2 x Western Digital Raptor 150GB
ThermalTake TOUGHPOWER 750W (Modular)
Silverstone TJ09 Black w/ window
Thermalright 120 Ultra Extreme
Logitech G15
Logitech MX518
Asus 18x SATA w/ Lightscribe
2 x Dell FPW2407 Rev A04
Old March 24, 2009, 01:52 PM
3.0charlie's Avatar
What about this Shuttle? NCIX.com - Buy Shuttle XPC X27 Barebones Mini PC Intel Atom 230 945GC DDR2-533 SATA Video Sound GBLAN - X27-BK-V1 In Canada. It has a DVI VGA output. You're only missing a single 2Gb Ram stick, and a 2.5" SATA HDD. Add Vista, and you're GTG.
Or this:
NCIX.com - Buy NCIX Value Bundle Deal Athlon 64 X2 BE-2400 Processor 2GB RAM & ECS GF6100 Motherboard -UNASSEMBLED - BE-2400-ECS-6100-2GB In Canada.
NCIX.com - Buy Coolermaster Elite RC-330 ATX Blk Case 4X5.25 2X3.5 5X3.5INT No PS 1X120MM Rear Fan Front I/O Panel - RC-330-KKN1 In Canada.
NCIX.com - Buy Corsair CMPSU-400CX 400CX 400W ATX 12V 30A Power Supply Active PFC 120MM Fan - CMPSU-400CX In Canada.
Hydro-Quebec is salivating...
Old March 24, 2009, 02:00 PM
sswilson's Avatar
Before you spend any money on components, go have a look at what FS or Staples have to offer in your price range. It sounds like your sister needs a decent general purpose computer, and the fact that she's going to need a monitor means that one of the pre-built kits will probably be the most cost effective solution for her (plus you'll get a legit OS to go with it).
It is very hard to put together a reasonably good complete system for less than you can find a better one at the big box stores. (10 years ago I'd have shot myself in the head before saying something like that..... :) ).
Old March 24, 2009, 02:01 PM
Default re
+1!
Old March 24, 2009, 02:02 PM
geokilla's Avatar
If your sister doesn't game, $500 should be enough for your computer, not including the monitor. Go check out Future Shop or Best Buy and see what they have for $500. May I also suggest a cheap laptop?
Actually, a quick browse at NCIX can get you the following for around $500 + tax.
NCIX.com - Buy NCIX PC E140 Athlon 64 X2 BE-2400 2GB RAM 250GB USB Sound Video LAN DVD 350W -ASSEMBLED - NCIXPC-E140 In Canada. or NCIX.com - Buy NCIX PC V140 Intel E5200 Dual Core 2GB RAM 250GB USB Sound Video LAN DVD 350W -ASSEMBLED - NCIXPC-V140 In Canada.
NCIX.com - Buy Acer X183H B 18.5IN LCD Widescreen Monitor Black 1366X768 10000:1 5MS VGA - ET.XX3WP.001 In Canada.
All you're missing is a set of speakers then you'd be good to go.
Old March 24, 2009, 02:19 PM
misterlarry's Avatar
My father-in-law needs exactly the same type of computer as your sister does. I told him that I would help him pick out a ready built unit at Best Buy or where ever. I couldn't really build him one for less and I didn't want to be obligated to lifelong support. I'll end up doing tech support for him anyways, but that will be because I want to, not because I have to. I want to retain my status as favorite son-in-law anyways (actually I'm the only one, but he still calls that).
In this case +1 pre-built.
Asus Z97-A - Intel i7 4790K @ 4.0 GHz - Corsair H80 CPU Cooler- 4x8 GB G.Skill Ares DDR3 2400 - EVGA GTX960 4GB
1x240 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 1X2 TB Western Digital Green - Pioneer DVR-212D - Antec P182 - Rosewill Photon 850 - 2X24" Acer G246HYL - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old March 24, 2009, 02:31 PM
The MAX's Avatar
I've been imaginary planning (aka want to build but don't have money but keep looking anyway) something like this for a while, but a little more high end.
The way I look at it and from what you say, these have to be the key features
-Small
-Storage for pics and movies
-Powerful enough for multitasking but nothing serious.
So heres what I just put together in ncix checkout.
First processor.
NCIX.com - Buy Intel Pentium Dual Core E5200 Dual Core Processor LGA775 2.5GHZ 800FSB 2MB Retail Box - BX80571E5200 In Canada.
Intel E5200 2.6GHz Core2Duo. Nothing to serious but dual core and decent speed.
Ram
NCIX.com - Buy G.SKILL F2-6400CL4D-4GBPK PC2-6400 4GB 2X2GB DDR2-800 CL4-4-4-12 240PIN Dual Channel Memory Kit - F2-6400CL4D-4GBPK In Canada.
G.Skill, just a decent 2x2GB set for 4GB so she won't have to worry about upgrading anytime soon. You could save yourself 25 bucks or so by getting a 2x1GB kit for 2GB but then if she needs to upgrade it could be a hassel finding similar ram...always is.
now for the money maker.
the motherboard
NCIX.com - Buy Intel BOXDG45FC MINI-ITX LGA775 DDR2 G45 PCI-E1 Audio GBLAN GMA X4500HD Video HDMI DVI Motherboard - BOXDG45FC In Canada.
Intel BOXDG45FC
takes core2duo but is in the small mini-itx form factor. its a little pricy, you could save 60 or 70 bucks by getting something like this
NCIX.com - Buy Zotac NF630I-D-E MINI-ITX LGA775 GeForce 7100 DDR2 1PCI-E1 2SATA2 RAID LAN DVI Motherboard - NF630I-D-E In Canada.
but it does not have a HDMI port and is probably not as high quality.
with that mobo and this
NCIX.com - Buy Apex MI-008 MINI-ITX Case Glossy Black 1X5.25 1X3.5 1X3.5INT Sfx 250W Front Audio USB - MI-008 In Canada.
nice little mini-itx case (with a 250watt PSU included) she can probably stick the comp anywhere.
Then for all here storage needs
NCIX.com - Buy Seagate Barracuda 7200.11 1000GB 1TB SATA2 7200RPM 32MB Cache NCQ Hard Drive OEM - ST31000340AS In Canada.
Seagate 1TB drive, dare here to try to fill it with pics and movies. lol
then a standard DVD
NCIX.com - Buy LG GH22NS30 Black DVD+RW 22X8X16 DVD-RW 22X6X16 DL 16X/12X 2MB SATA OEM - GH22NS30 BLACK In Canada.
and some monitor...
NCIX.com - Buy Samsung SyncMaster 2033SW 20IN Widescreen LCD Monitor 1600X900 15000:1DC 5MS 16:9 VGA DVI-D - LS20CMZKFV/ZC In Canada.
All of this with the ideas listed above in mind came to 702.74 before shipping/taxes
throw in some cheap keyboard and mouse and maybe speakers and you probably might go just a tad over 800.
Again you can cheap it up a bit with a different mobo, smaller HDD, and maybe 2GB of ram instead of 4GB but thats a pretty decent system by any standard.
I'd buy it. :)
- Antec 900 (modded) - Asus P5Q-Pro - 4GB Corsair Dominator DDR2-1066 -
- Palit GTX 260 SONIC 216SP - Core 2 Duo E8400 with Xigmatek HDT-S1283 cooler - 850watt Antec True Power Quattro -
Old March 24, 2009, 02:33 PM
crispex's Avatar
Old March 24, 2009, 02:42 PM
You basically confirmed what I was thinking...
I'll have a look at the links you sent, plus FS/BB/Dell...
Thanks guys!!!
INTEL Conroe E6700
ATI Radeon 4890
Logitech G15
Logitech MX518
Old March 24, 2009, 04:41 PM
I like that build "The Max". Maybe I'll go with that. Thanks again to everyone!
INTEL Conroe E6700
ATI Radeon 4890
Logitech G15
Logitech MX518
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
