Old March 20, 2009, 11:07 AM
Chilly's Avatar
The 750's more than plenty for that rig!
Old March 20, 2009, 11:55 AM
ImmaPC's Avatar
The TX750W will run that setup without a hitch. Only time you might have problems is if you were to SLI it, but mind you the 285 uses less power than 280 and the TX750W can just about handle SLI'd GTX 280's, so...
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
Old March 20, 2009, 12:37 PM
lemonlime's Avatar
Hardware Canucks Reviewer
Yep, TX750 is a great choice. Very solid PSU with an excellent price/performance ratio.
Old March 20, 2009, 01:24 PM
Rocco_360's Avatar
Hmmm, maybe I should get the TX 850 watt from corsair?
If 750 is cutting it close then 850 should be good enough wouldnt it? After all, after I do the mail in rebate it work sout to be the same price as the 750 :)
Old March 20, 2009, 01:32 PM
sswilson's Avatar
Define "just about the same price"......
If it was $10, I might consider it. Any more than that could be used to bump up something else in the system.
The 750 will be more than enough for what you want to do.
Old March 20, 2009, 01:34 PM
chrisk's Avatar
Folding Captain
The TX 750 is fine for your current build. 2 x GTX 285s in SLI might be a little close, but should still be fine. You will push about 500W at least with the SLI you are thinking of, which the 750TX should be able to handle for prolonged periods.
However if you can get the 850 TX for the same price and don't mind the rebate, then it couldn't hurt.
Fold for team #54196
Old March 20, 2009, 01:46 PM
Rocco_360's Avatar
When I say its just about the same price I mean that with the mail in rebate it goes to about $148.99 while the 750 watt is $146.99. I want the 850 in case I do choose to go for a second GTX 285. Instead of paying another $150 later on for an extra 100 watts.
Old March 20, 2009, 01:48 PM
Rocco_360's Avatar
Only a $2 differance :)
WTB: 750+ watt, cheapest possible elninio Buy/Sell & Trade 1 June 15, 2008 11:57 AM
WTB: Decent Modular PSU 500< watt Jackquelegs Buy/Sell & Trade 1 April 21, 2008 11:13 AM
Liberty 500 watt and x1950 agp, is it enough? Goti Power Supplies 12 October 23, 2007 07:42 PM
The Ultra X3 1000 Watt Corpus Masochist Power Supplies 4 July 20, 2007 03:06 PM
