Closed Thread
  #81 (permalink)
Old March 13, 2009, 10:20 AM
rjbarker's Avatar
Hey Sanjo......updated what?
You'll also notice in the past few Posts (got a little off Topic)...my comments re: FPS and my opinions on the subject, you'll also notice others "disagreeing"....but in no way does it get to the point of being "disrespectful"..........thats the beauty of this Forum.....
Firestrike Extreme: 21.452
MARK 11: 32.530
  #82 (permalink)
Old March 13, 2009, 10:37 AM
SanjoTHEBanjo
Guest
Posts: n/a
i updated the build on the first page...
  #83 (permalink)
Old March 13, 2009, 10:54 AM
Soultribunal's Avatar
There We go Sanjo, that is looking a lot better.
My only suggestion now is if your going for a 4gHz OC , that something other than the Domino, like the Freezone Elite or a Swiftech Pro Kit (with the HAF you can Mount that baby in the top easily.
My thoughts, the Domino might be hard pressed to tame an i7 with that kind of heat.
Regards,
ST
www.realhardwarereviews.com
  #84 (permalink)
Old March 13, 2009, 11:03 AM
llama_egg's Avatar
Doesn't the chip require like 1.7v to hit 4,000 and up? I could be mistaken about that, but I dunno how long the chip would last at those settings, even with a good cooling solution!
Seriously people, I am not a mod. Stop messaging me D:
  #85 (permalink)
Old March 13, 2009, 11:08 AM
Charlie has his at 4.0, and I don't think he needed nearly that kind of Voltage.
I could be wrong though,
ST
  #86 (permalink)
Old March 13, 2009, 11:14 AM
lowfat's Avatar
Mine probably would I am pretty confident I have the absolute poorest clocking i7 on the planet. 3.6GHz with HT requires 1.35V, and with that voltage it runs way to hot.
Mael
Big Lian Li
Forever Alone
  #87 (permalink)
Old March 13, 2009, 11:15 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
If I was planning on a long term hot rod'ed CPU I drop the coin on a Boreas. The Freezone Elite would be my next choice. 3rd would be water....but I don't think you would be happy with the Domino...or any single 120mm rad bay kit. Though if budget is not a concern and I wanted a really extreme cooler I would go for a Vapochill unit ;)
  #88 (permalink)
Old March 13, 2009, 11:17 AM
SanjoTHEBanjo
Guest
Posts: n/a
Default ok updated again.....
nvm just saw the price im sticking with domino seems great performance for 78 bucks
  #89 (permalink)
Old March 13, 2009, 11:44 AM
Realityshift's Avatar
Im pretty sure you guys are right on this one, that I7 is going to eat that domino alive, i would honestly just go with a true push pull over a domino, but thats just me.
EDIT: just took a look at your update, you have the elite in there now o.O? and still the flex ram? drop the water cooled ram and pick up some cheaper non water cooled ram or people might laugh histarically when they look inside your case.. as far as I know the elite does not allow you to run aditional cooling to things like ram, I may be mistaken but im pretty certain its a sealed unit.
The Builders Hammer
  #90 (permalink)
Old March 13, 2009, 11:49 AM
All this and here I'm hoping to hit 4.0 on my 965 on AIR lol...
I'm pretty sure that chip will eat that domino alive; I havn't had any time to play with my 920 at all but from what I've read: outlook not so good.
Closed Thread
Accelero XTREME GTX yycraven Air Cooling 29 July 9, 2009 04:04 PM
Finally decided to tinker with my Antec 900... Neolithium_Wpg Cases 3 November 2, 2008 03:56 PM
Freezer XTREME TopDogZero Air Cooling 2 October 16, 2008 06:00 AM
Build almost decided, need opinions on mobo + cooling Peppaaro New Builds 15 October 4, 2008 12:20 AM
Finally decided to get a new rig... Suggestions welcome! tda-danny New Builds 9 June 12, 2008 08:27 PM
