Closed Thread
  #121 (permalink)
Old March 13, 2009, 02:56 PM
Realityshift's Avatar
Yeah when I bought my LG GH22NS30 I think I paid $25 and the samsung Trudirect was like $28, but I was tryin to sip as much of my money by that time since I decided to go SLI =( we will see if that turns out to be a mistake. Like I said holding it out of the case and feeling the movements when opening and closing I dont have to much hope of it having a super long life. but then again every LG product ive owned has done very well so...
The Builders Hammer
  #122 (permalink)
Old March 13, 2009, 03:12 PM
3.0charlie's Avatar
Sorry for jumping in late (5 pages since noon, jeez...)
I've only bought LG drives for the past 2 years, no issues what-so-ever.
As for a 920 at 4.0, most definitely feasible on Air (TRUE with push/pull) while folding: 1.4V, 72C load temps, 23C ambiant. Same setup, under water: 57C.
Drop the 'raptor, and the Flex Ram.
Go for the Corsair HX1000W definitely.
You'll love the Elite, and the Donimo can't handle the heat dump of an oc'ed Quad.
Hydro-Quebec is salivating...
  #123 (permalink)
Old March 13, 2009, 04:40 PM
SanjoTHEBanjo
Guest
Posts: n/a
Complete overhall update... now im extreme :)
  #124 (permalink)
Old March 13, 2009, 04:49 PM
Supergrover's Avatar
You need to set your post count per page higher John.
  #125 (permalink)
Old March 13, 2009, 05:05 PM
SanjoTHEBanjo
Guest
Posts: n/a
now it is extreme :D
  #126 (permalink)
Old March 13, 2009, 05:23 PM
"Quote This..."
The p5Q is actually quite midrange for an x-58. Look at the evga classified or the asus rampage extreme or the foxconn bloodrage. They aren't much more either.
  #127 (permalink)
Old March 13, 2009, 05:24 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Now your getting there....now all you need is a dedicated RAID controller for those SSDs ;)
  #128 (permalink)
Old March 13, 2009, 05:25 PM
SanjoTHEBanjo
Guest
Posts: n/a
gaming boards are a waste of money. I remeber the rampage forumla and the p5k deluxe i believe. Someone found on the p5k deluxe there is a sticker that cover up the rampage forumla logo. bloorage is suppose to have a bad bios and the evga classfied is going to cost like 600 canadian... no thanks
  #129 (permalink)
Old March 13, 2009, 05:28 PM
SanjoTHEBanjo
Guest
Posts: n/a
nah onboard raid on x58 is excellent so its not needed. Im going to use that pci slot for a sound card later on
  #130 (permalink)
Old March 13, 2009, 05:39 PM
Triggz's Avatar
Actually squeetard is right. If you really want to push everything to the ExTrEmE (and you have made it quite clear to all of us that you do) I would look at some of the more high end boards. You will be able to 1. overclock it more 2. have room for a true quad sli + extra pci slot.
Or spend some extra money and try and get your hands on a good batch number of the 920. People run into road blocks with overclocking just because they got a lousy batch number. Or go for a 965. Yes it is proven that your not going to get much more out of it when it comes to STOCK. But its a whole new ball game when it comes to overclocking.
Case:Antec P182
MoBo:EVGA X58 Tri Sli
CPU:Core i7 920 (Batch#3841A)
RAM:6BG Aeneon DDR3-1866MHz
GPU:EVGA GTX 285
DATA HDD:Western Digital 640GB Caviar Black (x2 soon)
OPTICAL:LG GGC-H20L Blu-Ray
PSU:Corsair HX1000W Modular
WATERBLOCK:???
RES:Swiftech
PUMP:Swiftech MCP655
Display: Sony 40" w series 1080p + Dell 2209WA
OS:Windows 7 Ultimate x64 Bit
Closed Thread
Accelero XTREME GTX yycraven Air Cooling 29 July 9, 2009 04:04 PM
Finally decided to tinker with my Antec 900... Neolithium_Wpg Cases 3 November 2, 2008 03:56 PM
Freezer XTREME TopDogZero Air Cooling 2 October 16, 2008 06:00 AM
Build almost decided, need opinions on mobo + cooling Peppaaro New Builds 15 October 4, 2008 12:20 AM
Finally decided to get a new rig... Suggestions welcome! tda-danny New Builds 9 June 12, 2008 08:27 PM
