Closed Thread
  #101 (permalink)
Old March 13, 2009, 12:11 PM
Realityshift's Avatar
Sorry, enlightem me?
The IC7 Diamond thermal paste trials that HWC is doing? theres a sticky about it in the overclocking section, free tube of paste to test it on everything youve got and post about it, and from the looks of it it may perform pretty good, its got quite a bit more thermal transfer then silver.
edit
Free innovation cooling 7 carat diamond tim giveaway!!
The Builders Hammer
  #102 (permalink)
Old March 13, 2009, 12:16 PM
rjbarker's Avatar
Huh....I ended up using the goop that came with the TRUE...all the info I found on that stuff stated it was good...but in all honesty...even if I brought my Temps down a few more degrees, the gains associated with the 4Ghz I had were minimal at best...not worth the extra Voltage required. Anytime you can take a Stock 2.66 Ghz and get it to 3.8Ghz with very little jump in Voltage...hell...thats awesome....you said it best...if your looking for a 3.4 to 3.6 Ghz OC and get more..its a bonus!
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
  #103 (permalink)
Old March 13, 2009, 12:19 PM
Yeah, I applied for the trial because a) it would be nice to give HWC a hand where I can, and b) im running some random Antec copy of arctic silver and id really like to see how diamond based holds up against it, if anything its non conductive non capacative. plus I need to do my MCP anyhow its running at 71c load right now when I run SLI.
The Builders Hammer
  #104 (permalink)
Old March 13, 2009, 12:33 PM
rjbarker's Avatar
Hey in Prince George.....I have to fly up to Rupert on the 23rd for work....you still have winter thier?
  #105 (permalink)
Old March 13, 2009, 12:38 PM
Supergrover's Avatar
Glad to see everyone playing nicly today, blame it on the full moon yesterday.:)
Sanjo: Build looks way better now bud others have made there comments I will just say 1, I freaking HATE lite-on, or any rebranded lite-on, drives everyone has died on me , even my dvd recorder standalone unit.
Pioneer or a Sammy would be my choice.
  #106 (permalink)
Old March 13, 2009, 12:43 PM
rjbarker's Avatar
Hey SG..what are your thoughts with LG? Personaly my Prime Rig has a Sammy and a Asus, my 2nd has an LG.
  #107 (permalink)
Wow I didnt even notice that part, I 100% agree with that, lite-on is an OEM brand at best, I have had every one of their products fail on me within months of owning them. Go with the choices listed, I really like samsung but the LG burner I bought seems to be good so far. I still wish I had spent the extra $3 and just gone with the Samsung speed+.
The Builders Hammer
  #108 (permalink)
Old March 13, 2009, 12:47 PM
Last LG I owned was a first GEN dvd rw, thing cost me over 5 bills but you know what that sucker is still burning the odd disc today in the wifes rig. Other than that I havnt used any newer LG units.
  #109 (permalink)
Old March 13, 2009, 12:49 PM
rjbarker's Avatar
Yeah I've got two 5 yr old ones as well in my Wifes Office Rig (my old P4 w 6800GT) - still works fine. Back then they were about quadruple what I pay now.
  #110 (permalink)
Old March 13, 2009, 12:53 PM
I got an old LG multi writer out of an external drive bay I wanted, it was marketed as an external DVD writer but I just wanted the drive bay, so the writer itself went into my PC. I picked that up oh... 4-5 years ago when zellers in fort st john was going out of buisness. I think I paid $45... 85% off. The thing is still burning today although I no longer own it, I really hope the newer Sata drives last near as long, I just dont like the quality of the LG superwriter I picked up, its loud and feels cheap.
The Builders Hammer
Closed Thread
Accelero XTREME GTX yycraven Air Cooling 29 July 9, 2009 04:04 PM
Finally decided to tinker with my Antec 900... Neolithium_Wpg Cases 3 November 2, 2008 02:56 PM
Freezer XTREME TopDogZero Air Cooling 2 October 16, 2008 06:00 AM
Build almost decided, need opinions on mobo + cooling Peppaaro New Builds 15 October 4, 2008 12:20 AM
Finally decided to get a new rig... Suggestions welcome! tda-danny New Builds 9 June 12, 2008 08:27 PM
