Closed Thread
  #91 (permalink)
Old March 13, 2009, 11:50 AM
Realityshift's Avatar
With a good set up im sure youll get 4.0 on air man, trues with push pull put out alot of cool and these cpus have a pretty high temp threshold from what ive been reading they just plain run hot.
The Builders Hammer
  #92 (permalink)
Old March 13, 2009, 11:54 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Sanjo....go w/ a OCZ Vendetta 2, drop a decent fan on it and you will save money, prolly get better numbers (and lower noise levels) than going w/ the Domino. Its not designed for major OCs. Its a VERY good entry level WC all in one kit...but what you are doing is NOT entry level. I would strongly recomend either saving a few bucks and going air...or save it somewhere else and spend a couple more for a better all in one kit (or better yet a decent DIY WC loop).
  #93 (permalink)
Old March 13, 2009, 11:57 AM
rjbarker's Avatar
I7 920 - 3.8 Ghz - P95 Stable - vCore 1.2375 "without vDroop" 1.28v under load - TRUE Push - Max Temps 67C
I7 920 - 4.02 Ghz - P95 Stable - vCore 1..35 "without vDroop" 1.39v under load - TRUE Push - Max Temps 81C
For 24/7 4 Ghz I'd have to get another 120mm and go "Push / Pull"...but the difference from 3.8 to 4 is not noticeable enough to bother.
Firestrike Extreme: 21.452
MARK 11: 32.530
  #94 (permalink)
Old March 13, 2009, 11:58 AM
now that would be EXTREME!
The Builders Hammer
  #95 (permalink)
Ouch RJ 81c? how are your case temps let alone your motherboard temps after that?
The Builders Hammer
  #96 (permalink)
Old March 13, 2009, 12:01 PM
rjbarker's Avatar
That was running at those Temps 77 / 81 / 76 / 80 for 4 hrs of Prime.....Case Temps were low, NB Temp was around 61C (still not bad)...Silverstone TJ09 moves a lot of air...
Temps are a result in jump in vCore to get stable, Temps at 3.8 are about 10 - 12C cooler.
MARK 11: 32.530
  #97 (permalink)
Old March 13, 2009, 12:03 PM
Yeah I forgot you had that high end expensive case =P thats still pretty decent for a single fan true. you going to test that rig with the Ic7?
The Builders Hammer
  #98 (permalink)
Old March 13, 2009, 12:05 PM
rjbarker's Avatar
i7 920 OC @ 4Ghtz
2x XFX GTX 285 in SLI
CooliT Freezone Elite w/ Retention Bracket for 1366
WD Velociraptor 300GB
WD Cavier Black 640GB
22x SATA Lite-On DVD Burner
CM HAF 932 Case
Corsair 850w PSU
6GB OCZ FLEX 1600MHZ 7-7-7-24 Kit
EVGA x58 Motherboard
Nice Rig thier Banjo, however, definitely change up that PSU and go straight to a Corsair HX 1kW for that set-up!!
Stick to a TRUE Push / Pull config...its proven.
Bear in mind, 4Ghz is not guarenteed.....
Having had a Raptor drive and change it out for a 640 Black in a heartbeat...noisy as hell and no noticeable gains...the only difference I see is how "quiet" the 640 Black is!
MARK 11: 32.530
  #99 (permalink)
Old March 13, 2009, 12:08 PM
rjbarker's Avatar
Sorry, enlightem me?
The only thing now I'm thinking of doing is ditching this 74 GB Raptor and getting another 640 Black or 500 Black....I hate this Raptor more n more each day..I'll sell it cheap if I decide to change out....means compete re-install ;( I hate that when everything is running nicely!
MARK 11: 32.530
  #100 (permalink)
Old March 13, 2009, 12:10 PM
+1
Thats some good advise right there, with what you have listed already and what RJ just pointed out you would have one hell of a good computer that should last you quite a while. I thought when I bought my E7400 that 4ghz was garenteed because I saw so many people hitting over 4ghz in reviews, in reality 3.8ghz was the limit I could get within decent voltages =( so dont plan for 4ghz and then be pissed when you dont get it, plan for a 3.6-3.8 for 24/7 and be very happy if you get more =)
The Builders Hammer
Closed Thread
Accelero XTREME GTX yycraven Air Cooling 29 July 9, 2009 04:04 PM
Finally decided to tinker with my Antec 900... Neolithium_Wpg Cases 3 November 2, 2008 03:56 PM
Freezer XTREME TopDogZero Air Cooling 2 October 16, 2008 06:00 AM
Build almost decided, need opinions on mobo + cooling Peppaaro New Builds 15 October 4, 2008 12:20 AM
Finally decided to get a new rig... Suggestions welcome! tda-danny New Builds 9 June 12, 2008 08:27 PM
