-   -   need help with video card set up (http://www.hardwarecanucks.com/forum/new-builds/15332-need-help-video-card-set-up.html)
ted copple February 28, 2009 07:30 PM
i'm going to build a new computer and i have picked out most of the parts and the mother board i have is 3 way SLI ready an i was just wondering because it's 3 way SLI dose that mean i can only set up one or 3 video cards or is it possible to use only 2 cards because thats all i can really affored.
thanks for any replys.
CMetaphor February 28, 2009 07:32 PM
Of course you can two way sli on a 3-way board. Or you can two way sli now and 3-way later, OR you can two-way sli now and add in a third video card by itself later to use as a physics processor! :thumb:
Dogger1 March 1, 2009 12:57 AM
CM's right on the money.
You can always download the user manual for the motherboard you're planning on using and take a look at how the manufacturer suggest you configure the board for a single, dual and 3 way.
