Old February 17, 2009, 06:34 PM
Default new build and overclocking help
hi guys. i was wondering if i could get some:help: with oveclocking my system. i currently want to reach at least 3.6Ghz on air cooling. rate system too please
System:
Core i7 920
6Gb Corsair Dominator 1600Mhz
Evga X58
Thermalright ULTRA-120 Extreme CPU Heatsink
ULTRA X3 1000W PSU
Thermaltake Spedo Advanced Package
PROBLEM: I DONT KNOW HOW TO OVERCLOCK. can anyone help me? i've read articles, but how they explain it is all over the place. i need something straight forward please.
Old February 17, 2009, 06:41 PM
3.0charlie's Avatar
You have to read and learn how to oc... this guide may not be your board, but it's relatively well explained.
It's a pdf too. GIGABYTE shows how to overclock i7 920 CPU to 4GHz :: TweakTown
Hydro-Quebec is salivating...
Old February 17, 2009, 06:48 PM
Jake_HT's Avatar
The best way to OC with the i7, is borrow someones settings at 3.8GHz, plug them in and try it.. there is so much stuff to turn off and on, it's a confusing way to learn how to OC
Good luck! I got 3.8GHz outta mine with good voltage and temps.. 4.0GHz is possible too but I'd just rather run at 3.8 with better temps and volts. i7 overclock very well.
http://jakeht.deviantart.com/
Old February 17, 2009, 08:23 PM
ImmaPC's Avatar
If you have no clue how to overclock (I'm assuming with ANY CPU), I would learn how to overclock an LGA775 CPU as it's probably the easiest one to do so with. i7 is a horrid platform to overclock on, it can get kinda confusing at first and takes a bit to adjust. Do what JakeHT said and borrow someone else's settings if you can't hack it and want to cut to the chase. Shouldn't this thread be in the Overclocking, Tweaking, and Benchmarking board?
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
Old February 18, 2009, 01:07 AM
Hail Ceasar's Avatar
EVGA posted a great OC guide at EVGA.com
EVGA X58 Overclocking Guide
Intel i7 Quad Core 920 @3.8GHz | eVGA X58 x3 SLI | HAF 932 | Corsair 1000w | WD SSD 256gb | WD 3200 1TB | Seagate 2TB | 6x2GB DDR3 Mushkin XP3| MSI GTX 680+EK WB| 24" BENQ E2400HD | 19" Samsung 953BW
Swiftech 655 | Swiftech MCR220 | Apogee GTZ+1366 | EK Spinbay Res | EK Waterblock | Primochill 5/8" | Bitspower Compression Fittings
Old February 18, 2009, 10:21 AM
Soultribunal's Avatar
+1 on the Corsair Memory, I've never had issues with them. Rock stable for me.
+2 on the Ultra X3 1000w (although this is probably overkill for that system).
Good review of that unit is here :
JonnyGURU.com - Power Supply Reviews and more! - Reviews - Ultra Products X3 1000W
Overall system looks good, as for the OC part of it, I would suggest making a new thread in there with full system specs and asking the Guru's of the OC world to take a peek.
Good Luck,
ST
www.realhardwarereviews.com
Old February 26, 2009, 07:37 PM
bump .... need to know info
Old February 26, 2009, 07:41 PM
Jake_HT's Avatar
Are you the OP with a new name?
Have you read through some of the links posted on overclocking the i7? Read around, find some settings, give them a shot. That's what I did and it worked very well for me.
EDIT: I'm under the impression that you already have this system..
Overclocking and Cpu-Z CactusJoe Troubleshooting 15 December 9, 2008 02:59 PM
AMD Overclocking ?? cwestwell New Builds 16 October 20, 2008 01:39 PM
About Overclocking blogz101 Overclocking, Tweaking and Benchmarking 0 July 28, 2008 07:17 PM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 07:41 PM
