Old February 15, 2009, 11:56 AM
Sorry guys, thought the attachment would open up to a larger image.. I added another link to the image, now you can zoom in to see what is in the build.
Just woke up, will come in later on to read more! Thanks!!!
Old February 15, 2009, 12:16 PM
I will have to have an OS no matter what, I guess I can download uBuntu for the time being?? Will it work with all this setup and call of duty 4? If yes then will buy Vista in summer.
The PSU I thought is enough power, no? 850 maybe but 1000 would be killing it, don't you think?
I too heard of the P6T Deluxe V2 but the only difference Asus says is they removed the SAS.. maybe they're hiding something?
As for video card, 260 is not capable of playing HD on 24inch? :S I thought it was :(
How is the 285? NCIX.com - Buy EVGA E-GEFORCE GTX 285 648MHZ 1024MB 2.489GHZ GDDR3 PCI-E Dual DVI-I HDCP HDTV Out Video Card - 01G-P3-1281-AR In Canada.
Also I was looking at different video cards and the only one that has an HDMI out is the 295 which is on the expensive side. I don't get it why don't they include HDMI on every card? Do you know any 260, 280s that have HDMI out port?
Old February 15, 2009, 02:33 PM
Infiniti's Avatar
I think CoD4 will work fine in Ubuntu if you use Wine.
Your PSU is enough.
No comment.
The 260 should be fine playing on a 24 inch. I'm on a 37" 1920x1080 HDTV, and all my games run smoothly.
My 37" only has HDMI, but NVIDIA includes a dongle for DVI-HDMI, so all you'll need is an HDMI cable and you should be good to go.
Old February 15, 2009, 02:44 PM
sswilson's Avatar
For your OS... do some googling for the games you want to play and see if they run fine under the Windows 7 Beta. If they do, you'll have the free use of an OS until august. :)
Old February 15, 2009, 02:48 PM
Never thought of it that way. thanks!
Old February 15, 2009, 03:23 PM
JD JD is offline
Chances are everything will work in Windows 7 Beta. So that's probably the smartest choice for now at least.
Going Linux isn't the smartest though if you want to be doing gaming IMO.
Old February 15, 2009, 04:50 PM
Triggz's Avatar
Welcome to the forums!!!
Just a quick point on the "customer service" concerns you have with Direct Canada.
We've got a Direct Canada rep here at HWC (username = DC_Support)who's been able to smooth through the great majority of issues folks have had with Direct Canada (Not that there have been all that many aside from the industry wide on-line meltdown of Christmas `07 :) ). He's been very quick to respond, and has provided many of our members with superb personalized service.
I'm not suggesting that you chose Direct Canada (that's up to you to decide), but the free shipping deal often makes them the best choice if you're including a (heavy) case in your order.
Thanks for the info! I read the customer service review/opinion somewhere on here... But it is really good to know there is someone here to talk to if you have any problems! Good on you DirectCanada!
Old February 15, 2009, 06:50 PM
LCB001's Avatar
Folding Captain
One other difference between the P6T Deluxe V1 and V2 is the new version supports 24 GB ram, the V1 only 12GB according to the listed specs...
Folding For Team 54196
  #19 (permalink)
Old February 15, 2009, 07:10 PM
Sure his games will work fine under windows 7 but if he doesnt already have a copy of the beta its kind of too late, at least to get it directly from Microsoft, as they closed the downloading on friday I think.
  #20 (permalink)
Old February 15, 2009, 07:37 PM
JD JD is offline
Yeah but it's easy to find on torrents
Tags
new build
First Time Build Need Help and Opinions Modestyle New Builds 35 February 28, 2009 05:30 PM
Next Budget Build - H2O This Time BALISTX New Builds 13 October 5, 2008 03:04 PM
Well it's off to the races again New Build Time :) tgraszat14 New Builds 5 July 26, 2008 09:07 PM
First time build CGW Troubleshooting 10 September 12, 2007 07:27 PM
PC Build - first time! Simulation! Mike CPU's and Motherboards 28 April 14, 2007 04:57 PM
