Old February 10, 2009, 07:33 AM
Default Just finished my 1st build
I'm not a complete computer n00b but never having built a computer from scratch before I found the whole proposition to be a tad daunting; especially when I had all the parts laid out on our kitchen table.
I'm sort of amazed that I only made 2 errors on the whole build and they were easily remedied. Actually I found that the whole thing was a complete blast, from selecting the parts, to completing the build.
Here are the components that I used:
Intel Core i7 920 Nehalem 2.66GHz
ASUS P6T6 WS Revolution motherboard
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit
COOLER MASTER HAF 932
CORSAIR CMPSU-850TX - In retrospect I should have used a modular PSU
XFX GTX285
Western Digital Caviar Black 640GB
Cooler Master V10
Asus 22X burner
Microsoft Windows Vista Home Premium SP1 64-bit
FYI, my idle temps with the V10 were a rather amazing 27C but it 's got to be the biggest, loudest and most expensive air CPU cooler around. Installing it in the HAF was a breeze but it really dominate the landscape. lol
I'll post some pictures of the rig in the next couple of days and hopefully be able to report some temps of the V10 under load. I'd love to see what Hardware Canucks thinks about this cooler and hopefully a full review is in the works.
I must have read well over 100 threads on these forums and wanted to thank you all for sharing your expertise. I also found the review of the Cooler Master HAF to be spot on and with all those fans huge fans blowing directly on the V10, I've got to think that was a contributing factor in the low temps.
Old February 10, 2009, 09:05 AM
Do you mind telling what the 2 mistakes were because I am just waiting on my parts to get here and if I can avoid the mistakes you made it would be greatly appreciated, thanks.
Old February 10, 2009, 09:40 AM
Andy's Avatar
Sounds like fun! Definitely take some pics of that cooler. I would lake to see how much space it takes up in the HAF. :)
SAGER 5165 - Matte Screen (1920x1080) - i7-2630QM - nVidia 555M - 8Gb DDR3 - 120Gb Corsair Force GT SSD - 500Gb Momentus XT - Intel® 6300
Old February 10, 2009, 10:30 AM
JD JD is offline
Definitely need to post some pictures and could you put the font size back to default? No need to make it so big...
Old February 10, 2009, 11:54 AM
Soultribunal's Avatar
Awww comeone JD, he's probably just bloody happy that:
1) He didn't start a small fire
2) It worked
3) Its just that damn cool to own new parts
4) That if all else failed, he could just fold and double the rig as a space heater
Waiting for the pics!
good job,
ST
www.realhardwarereviews.com
Old February 10, 2009, 12:07 PM
Jake_HT's Avatar
Nice build! And definitely interested on seeing some of that v10 cooler.. things are HUGE!!!!!!!!!!
http://jakeht.deviantart.com/
Old February 10, 2009, 03:32 PM
JD JD is offline
Hey, don't steal my idea!
Yeah I know, I'm sure he's overly happy, I'd be too myself with a shiny new i7 rig, but I just find the big fonts a bit too "in my face".
Old February 10, 2009, 03:53 PM
I'm really vision challenged and the larger fonts help me read the text at a reasonable distance. Otherwise I end up leaning into the monitor, which is a pia.
The mistakes I made were:
I didn't use the PSU units dedicated 8 pin connector to the motherboards EATX12V but tried using the PCI-E 6 pin, with the attached 2 pin connectors. The motherboards EATX12V has a series of square and U shaped holes and with my poor eyesight it looked like the dedicated 8 pin connector wouldn't fit but it did.
I installed the CPU cooler so it blocked access to the PCIEX16 slots - duh stupid n00b mistake, which I can't blame on my poor eyesight
I will take some pics but my wife's back in Buffalo visiting her relatives and took my camera with her. I mean really, which is more important, pics of the relatives, or pics of the computer?
The v10 doesn't take up all that much space in the HAF but compared to other coolers, you can't help but notice it.
lol soultribunal
BTW, I downloaded the user guides for the motherboard and the HAF to my old computer, which allowed for enlarged images of everything. That definitely facilitated my build because all I had to do was look at my monitor, vs. grabbing the printed instructions, finding the right page, balancing the instructions in one hand etc.
I also mounted a 120 fan in the slot on the bottom of the HAF and routed the wires to the rear panel; so the bay has as much clean airflow as possible.
Old February 10, 2009, 04:01 PM
1Tanker's Avatar
Sounds good Dogger1.
That's a rhetorical question, right?
Old February 10, 2009, 06:41 PM
JD JD is offline
Well if you have problems reading you could just increase your browser font size too, which in Firefox at least, increases the size of what you type in the textbox too but when you post it, others would see it at normal size.
And don't think I'm picking on you or anything, I don't really mind. My dad has to increase the font size in Firefox to read anything too, though you should consider seeing an eye doctor .
New rig finally finished ... for now NyteOwl Case Mods, Worklog & Gallery 8 September 3, 2008 08:37 PM
Apollo4g's MM Horizon Case Picture Log (Finished) Apollo4g Case Mods, Worklog & Gallery 21 May 31, 2008 10:40 PM
never finished flybye Case Mods, Worklog & Gallery 1 September 11, 2007 10:42 AM
