Old February 10, 2009, 12:11 PM
You could do AMD also if you want with other parts jdrom17 listed. If you don't overclock it seems to be better.
GIGABYTE GA-MA770-UD3 AM2+/AM2 AMD 770 ATX AMD Motherboard
AMD Athlon 64 X2 7760 Kuma 2.7GHz SocketAM2+ 95W Dual-Code black edition
Total 625.87$ USD before any shipping or taxes.
Review Here : AMD Athlon X2 7750 BE review
Old February 10, 2009, 02:18 PM
geokilla's Avatar
Originally Posted by jdrom17 View Post
Don't get the PSU combo and get whatever case you want, such as the Antec 300 and the OCZ StealthXStream 500W. Great PSU for the price. My AMD X2 rig with X850XT has that PSU. It also comes with a 8 pin PCI-E connector.
You might want to be careful with that 4850 since it doesn't cool the RAM chips. Good airflow is recommend if you're going to get that GPU.
Old February 10, 2009, 03:53 PM
JD JD is offline
Eh that PSU combo deal was cheaper than buying a 550W Corsair and for what he's doing, it would be fine.
Also Newegg.com (remember he's in the US) doesn't have the StealthXStream 500W. Only the StealthXStream 600W and then it would be like $10 more than the Antec 300 + Antec 650W Combo.
And I'd say that 4850 does cool the RAM since the fan that's on the heatsink would blow over them as well. Even if it doesn't, the Antec 300 has plenty of choices to get air flowing through.
What to DO and NOT DO when building a PC. Moneyless Guides & How-to's 41 December 7, 2009 06:19 PM
Building my first PC. Rolay New Builds 12 October 12, 2008 07:06 AM
Building Phobia Off Topic 9 September 21, 2008 12:29 PM
Building New Rig swiftk1 New Builds 7 August 27, 2008 02:16 PM
Building a new rig, need help(im new) NoobLordSpud CPU's and Motherboards 22 July 10, 2007 07:53 AM
