Originally Posted by baka101 The 9800GTX and HD4850 are both out of my price range, and due to living in new zealand and exchange rate we don't get the mass of choices when it comes to buying computer parts or competitive prices unfortunately. |
Well that 9800GT 1GB goes for $180-200 here in Canada and so do the HD4850s and 9800GTXs. I'm not quite sure why that wouldn't transfer over...
Originally Posted by baka101 But thanks for the idea about get another stick of ram I decided to go with a extra 2gb of ram even though windows may read it as 3.5gb etc plus I already have 2gb of ram in there and only have one more slot available. Also you guys can't seem to find a possible bottleneck in my system like the CPU maybe holding it back or seagate HDD etc. |
When you upgrade to a 64bit operating system, you'll be able to use all 4GB. You should be moving to 64bit this year, next year at the latest come Windows 7 since I'm guessing you skipped Vista.
Also I don't see anything else being a bottleneck. Sure the hard drive always technically is since it's the slowest piece in every PC but upgrading to something "faster" isn't going to do much for gaming.
Originally Posted by baka101 Anyway how come don't go with the 1GB version of 9800GT won't it compliment my Samsung 2693HM 26" lcd monitor with max resolution of 1920x1200 or doesn't anything use that much ram. |
Well you see the GPU itself (9800GT) simply isn't fast enough to be able to render 1GB of textures in one go. So that memory for the most part will probably just sit empty. I don't understand why some manufactures pump up the amount of RAM on slow GPUs. It's even more stupid when they shove 1GB on a 9300GT. It makes the card seem "faster" to an average consumer that doesn't know anything about video cards, which you seem to have fallen for. However in real-world application, it doesn't help. But of course there are exceptions to this, for example the 1GB HD4870 is quite a bit quicker than the 512MB version because the actual GPU is fast enough to be able to handle the additional data.
And TBH, if you have a 26" LCD, a 9800GT isn't going to be that great. You should really try and go for a HD4870 or GTX260 but I guess since you've been using a 8600GT all this time, a 9800GT will be faster anyways but I doubt you could run maximum settings.
