Old February 5, 2009, 04:56 PM
Default Portable Micro/Small Mid ATX Build
Mainly, web browsing, gaming and media viewing.
Approximately $550-$600.
USA, Newegg
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
A bit of an Intel fan but I could go AMD if I need to.
Vista 64, keyboard, mouse and monitor.
I was unable to find any.
Yes, most likely only the CPU though.
Within a month.
I'm looking for a decently portable desktop that's stable, reliable and fairly fast. I would like it to be somewhat future proof to minimize the impact on my wallet later down the road when I upgrade.
Best,
Trevor
Old February 5, 2009, 05:01 PM
yikes, that budget is small...what's the resolution of your monitor? I tihnk we need to add that question into the required ones too! For gaming, resolution matters in regards to what vga you use!
Old February 5, 2009, 05:04 PM
1680 x 1050.
Old February 5, 2009, 05:08 PM
3.0charlie's Avatar
Hd4850, 9800gt.
Hydro-Quebec is salivating...
Old February 5, 2009, 05:12 PM
sswilson's Avatar
When pricing, keep in mind the OP is talking $550 - $600 USD purchased down south so it's a little bit more wriggle room than equiv. CDN.
Old February 5, 2009, 05:18 PM
Hd4850, 9800gt.
...which takes a large chunk out of that budget...but that doesn't mean we can't work with it...
Old February 5, 2009, 06:13 PM
Soultribunal's Avatar
Well, I'll do my plug for something....
To minimze cost , Ultra XBlaster is on sale now at TD which is all over the states too.
It is light enough, has enough room, no flashy stuff at all. Just get the one with the solid side.
Its cheap but it works.
Regards
ST
www.realhardwarereviews.com
Old February 13, 2009, 02:23 PM
Any other opinions?
Edit: Good news, budget just upgraded to 700 USD!
Old February 14, 2009, 09:13 AM
bojangles's Avatar
Try this...
CM 590 case
ASUS P5Q Pro
Intel E5200 (OC this thing to the max!)
Pioneer DVR-216DBK
Corsair PSU (If you want to futureproof, maybe get a TX650/750 or something)
XFX Radeon 4850
Any hard drive you want, but preferrably not a Seagate 7200.11 due to bricking issues from firmware etc. You can try the 7200.12's though.
Heatsink of your choice...I prefer the Xigmatek S1283 with backplate mounting kit.
That should come close to your budget I think.
Old February 15, 2009, 01:01 PM
Ok, I went a little (a lot) over budget to make this rig great. What do you think?
Newegg.com - Once You Know, You Newegg
Good Things in a Small Package - My H2GO Build zlojack Case Mods, Worklog & Gallery 80 March 25, 2009 08:12 AM
The Final Build (Good things in small Packages) Soultribunal New Builds 12 December 12, 2008 08:08 PM
Good price and portable? JMCD Water Cooling 27 November 22, 2008 07:35 PM
Small system build "Little Valley" yamawho Case Mods, Worklog & Gallery 8 July 30, 2008 05:19 AM
Rugged Portable HDD from I-O Data @ Everything USB Supergrover Press Releases & Tech News 0 December 10, 2006 11:14 AM
