Hello, I'd like some feedback and opinion regarding a new build. Thanks.
Word processing, spreadsheets and gaming.
$2000
Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Intel-Fanboy and nVidia-Fanboy.
No
Yes
Not until the product(s) go out of warranty.
This week.
Parts List:
Intel Core i7 920 2.66GHz [$357.99]
Seagate 500GB Barracuda 7200.11 [$64.90]
NZXT Tempest [$156.90]
PC Power & Cooling Silencer 610 [$114.90]
Kingston ValueRAM 3GB DDR3-1333 Triple-Channel CL9 [$112.90]
BFG NVIDIA GeForce GTX 285 OC 1GB PCIe 2.0 [$489.90]
Samsung SH-S223F [$41.90]
Gigabyte GA-EX58-UD3R [$252.90]
Total: $1592.29
