Hello everyone,
Those are the specs of a my new upcoming build. I will build it once my semester is over (in 3 months), but I thought I should get opinions as early as now. I know prices might drop from now until then, but I just want to make sure I am on the right track. I could buy some of the components as early as now if they are at a discount price/rebate.
I am going to use this computer for gaming (1280x1024)(19 inch monitor non-widescreen), Internet, and some audio/video editing/converting (nothing serious requiring a Quad Core).
Specs:
Intel E7400 --- 120$
Gigabyte GA-EP45-DS3L --- 100$ (85$ After rebate)
4GB of G.Skill RAM (2x2GB) --- 40$
MSI 9600GT 512M OC GeForce 512MB --- 110$ (85 After rebate)
Rosewill RP500-2 500W ATX12V v2.01 Power Supply --- 45$ ( I could replace this with an
OCZ StealthXStream OCZ500SXS 500W --- 60$ (25$ After rebate) if there is a need and the price difference is not big.)
As for HDs, I am debating between getting one 1TB HD and partitioning it accordingly or getting one small HD just for the OS and another big one for apps/media/backups. I just want to be able to re-install an OS without loosing everything. (I will be multi-booting)
As for the processor, I would like to overclock it to a speed that does not require a new heatsink/fan and/or huge voltages. I would really appreciate your opinion about this also (safe speeds/voltages/temps...)
My budget goes as far as 550$-600$. Please consider that.
Thank you for your time and for the feedback.
