Old January 20, 2009, 03:10 PM
Default need advice on graphics cards and hdd
hi i'm looking at buying 2 bfg 9800gtx+ to run sli but would the cheaper 9800gtx be ok or maybe the 9600gt i will be using it for mmo's i.e starwars galaxies also looking at a 150gb western digital velociraptor will i notice the difference in the speed or should i just stick withe the normal 500gb any advice welcome
i will be using the rig for gaming mostlylike i said mmo's and crysis etc, will be purchasing parts in uk
thanks for looking
andy
my rig so far:
thermaltake kandalf lcs
asus crosshair mobo
atherlon 64 x2 6000+
thermaltake 750w toughpower
Old January 20, 2009, 03:44 PM
Eagle Eye's Avatar
Personally I'd stick with the 9800GTX+ I don't see the 9800GTX around much and prices pretty much on par with the + edition as for the 9600GT that would be an even bigger step down from the 2. I'd look at some of EVGA products sometimes they tend to be cheaper than BFG and have comparable perks. Furthermore its important to consider that while SLI is a viable option you must consider how well the game will scale by that I mean will it utilize SLI to its full potential and also consider what resolution you'll be gaming at, I hate to see little to no improvement from just using 1 card and having spent all that money. You might also consider a single more powerful card like the GTX260 or Radeon 4870 1Gb although it could potentially be a little bottlenecked by your current setup it will offer you excellent performance at any resolution and will be a cheaper solution to purchasing 2 cards and you'll have room for a soundcard.
EVGA GTX260 - Price Comparison - Canada's Cheapest Prices It would be my choice to your current situation
EVGA 9800GTX+ - Price Comparison - Canada's Cheapest Prices
BFG 9800GTX+ - Price Comparison - Canada's Cheapest Prices
A 150Gb western digital velociraptor will always show a noticeable improvement, I think if your case if you can afford it A 500Gb or a 640Gb drive for your OS and applications and for speed the raptor for games.
http://www.shopbot.ca/default.asp?orderby=p&p1=&p2=&kw=WD+Velociraptor+1 50GB&position=search
WD 640GB Black - Price Comparison - Canada's Cheapest Prices
EE
Old January 20, 2009, 04:01 PM
geokilla's Avatar
I second a good 640GB hard drive. No need to spend that kind of money on a VelociRaptor.
As for your GPU, Get a 9800GTX+ or ATI 4850. More than enough for your needs assuming you game at 1680X1050. If you want more eye-candy for games such as Crysis, then the GTX260 Core 216 or ATI 4870 would be the way to go.
thanks for the advice motherboard came with its own sound card ASUSTeK Computer Inc. so space isn't a problem how will i know if the games i play will use all the sli ? also isn't 2x9800gtx+ gonna be better than one gtx260 this is the first gaming pc i have build i have a lot of trouble with lag on starwars galaxies and crysis well haveing alot of trouble playing that from start good idea about the hdd will look at them now
thanks again
Old January 20, 2009, 04:09 PM
rjbarker's Avatar
Uh.....is that not an Intel Chipset Board....doesn't support SLI. You have no choice but to go Single nVidia or 2 x ATI Crossfire....should make your decision making easier....you're purchasing in UK correct?
Here's a link a buddy over on another European vased Forum uses for pricing..
http://www.overclockers.co.uk/produc...d=701&catid=56
Good luck!
Firestrike Extreme: 21.452
MARK 11: 32.530
Old January 20, 2009, 04:12 PM
[quote=rjbarker;141258]Uh.....is that not an Intel Chipset Board....doesn't support SLI. You have no choice but to go Single nVidia or 2 x ATI Crossfire....should make your decision making easier....you're purchasing in UK correct?
Good luck!
the board is sli only it won't support the ati's
Old January 20, 2009, 04:16 PM
rjbarker's Avatar
Yep sorry, my mistake nForce chipset...
Anyhow...here's a possible GPU in UK
http://www.overclockers.co.uk/showpr...tid=56&subcat=
Cheers
MARK 11: 32.530
Old January 20, 2009, 04:20 PM
thanks mate will check the site out so is running sli better than 1 card?
Old January 20, 2009, 04:34 PM
rjbarker's Avatar
As Eagle E explained and I agree...a Single Card solution is preferable over Multi Cards....I run two because there were no options better than a 280 a few months ago except for 2 280's. You'll have to check Benchmark speeds etc but I would rather go with a decent 260 Core 216 or even a 280 over 2 x GTX 9800 +. I belive it would cheaper as well....not knowing your Budget nor Benches comparing 2 x 9800 GTX+ vs Single GTX 260 mkaes a little trickier, just Google it! Things definitely do look a little pricier there than here!
Also, yes, as mentioned, go with the Caviar Blacks vs the Velociraptor.
MARK 11: 32.530
Old January 20, 2009, 09:34 PM
Eagle Eye's Avatar
I used all CAD websites
Club 3D Introduces GeForce 9500 GT Graphics Cards MAC Press Releases & Tech News 0 July 29, 2008 10:24 PM
Asus creates new GPU future with upgradeable graphics cards stoanee Rumor Mill 13 July 20, 2008 10:15 PM
First Look: NVIDIA GeForce 9500GT 55nm Graphics Cards MAC Press Releases & Tech News 11 July 9, 2008 06:42 PM
What's your most trusted brand of AMD/ATI graphics cards? Mibs Video Cards 22 July 1, 2008 09:37 PM
The Best Gaming Graphics Cards for the Money: March 2008 vertex112 Video Cards 2 March 7, 2008 11:38 AM
