Old January 17, 2009, 06:38 AM
S_G's Avatar
S_G S_G is offline
Default Starting a new modding project, looking for the right parts to get me going
Okay, requesting that this thread be moved to the New Builds forum. I've pretty much turned this thread into a new modding project. Going to pick a case; currently deciding between the NZXT Whisper and Black Pearl, leaning towards the Whisper with an idea of replacing the front bezel with carbon fiber or texalium -- since the Black Pearl is all metal, but the front of the Whisper is plastic. See post #23 for where the real ideas are starting.
Original post below:
Did some quick searching on Newegg.ca for cases made of steel with lots of internal 3.5" racks. Came across this:
Newegg.ca - XCLIO 1000 Black / Silver 1.0mm SECC Steel ATX Full Tower Computer Case - Computer Cases
Looks ridiculous, but I kinda want one. Apparently weighs 25 lbs out of the box.
I'd have ordered it if it weren't kind of obnoxious with all the LEDs. The internals need a good paint job.
So... Any suggestions for cases? Looking for something that will support eATX motherboards (ATX, but wider), that has at least 6 3.5" HDD bays, and that I can work some water cooling into reasonably easily (I prefer externally back-mounted radiators). I'd also prefer aluminum/steel with less plastic.
Edit, candidates thus far:
It's all old! Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water (Goodbye, Skulltrail.)
Rocketfish LL case painted black // PCP&C Silencer 750W
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro (HD380Pro soon)
HTPC: E1200@3.2 + IP35 + 4GB DDR2-800 + HD4850 + Silverstone Kublai KL02
Router (WIP): Intel Atom 230 + Intel PRO/1000 GT + GS108T gigE switch + WRT54GL + a drawer
Old January 17, 2009, 08:17 AM
Here is a review on that XCLIO case.
I like the Antec 900 or the silverstone TJ09 but everyone has there own taste. I am not crazy about all the plastic tool less stuff in a lot of the new cases.
Old January 17, 2009, 09:43 AM
S_G's Avatar
S_G S_G is offline
Shame about the case. Functionally speaking, it seems great. It's just that the aesthetics are pretty bad.
I'm currently leaning towards the NZXT Whisper case. Enough room for me to add in 3 more HDDs, plus an extra 10 if I get two 5-in-3 HDD trays, and I'd still have one bay left over for my optical drive. Plus, it's got a bunch of sound dampening foam, which is nice to see included, and tubing holes in the back.
The price is low enough that I won't cry a river when I screw something up while modding it. I'd plan on cutting some more cable management holes, as well as another hole behind the CPU socket for easy backplate access, after which I'd give it some paint.
I'd like the front a LOT more if it didn't have that stupid V shaped thing on it, and instead only had the rail type thing.
[youtube]RAxkJhDKJM4[/youtube]
Also, is it just me, or does 3D Game Man always seem super duper hyperactive? I like his reviews though.
Old January 17, 2009, 10:49 AM
Exmortis's Avatar
Lian Li 20xx Plus II series 12x3,5 drives. I have the older 2000 PLUS 2, cooelr with 2x120mm and 2x80mm fans then my old NZXT Zero with 7x120mm and 1x80mm.
Exmortis's System
Corsair 600T White
Asus P8Z68 Deluxe /Gen3
Intel i7-2600K w/Corsair H100
8GB Gskill DDR31600 cl7
MSI Lightning HD797 Lighting
OCZ Revo 3 240GB
OZC Vertex 3 240GB
WD Velocirapter 600GB
LG DVD burner
LG BluRay Burner
Sound Blaster XFi Titanium PCIe
Windows 7x64 Prem
Asus VE24/VE27/VE24
Logitech Z-5450 5.1 speakers
Corsair AX850 Gold PSU
Corsair K90 Keyboard
Logitech G5 Mouse
Old January 17, 2009, 11:25 AM
JD JD is offline
I've seen that Xclio case in person and Canada Computers and gawd is it awful. No way it's worth $320 (only $240 at Canada Computers). The one on display was actually broken too. On of those door/fan things was busted off and just hanging by the fan cable. And worst of all the plastic used on them was so cheap looking for a rather high-priced case.
I'm fairly sure that ABS one is a Lian-Li, same with the Tagan (I think?) model which looks the same.
Old January 17, 2009, 11:46 AM
3.0charlie's Avatar
You can't go wrong with any Lian-Li's (except they're mostly Alu.) and the Black Pearl.
Old January 17, 2009, 12:28 PM
Chilly's Avatar
That XCLIO looks like something taken out of a house fire.
Old January 18, 2009, 12:24 AM
S_G's Avatar
S_G S_G is offline
Guess it's between the Black Pearl and the Whisper. I'm really annoyed right now. I spent an hour in Photoshop mocking up what the Whisper case would look like with my cutting, painting, and water cooling. And the damn thing crashed!
Old January 18, 2009, 12:40 AM
Infiniti's Avatar
I would prefer the Black Pearl. Maybe because it's higher quality, but it seems like the front of the Whisper is all plastic, which is a big no-no.
Old January 18, 2009, 01:11 AM
Eagle Eye's Avatar
Its the first thing I noticed about the Whisper was how cheap that front panel looked, I couldn't agree with you more Infiniti the tagan says much better qaulity.
Although, S_G the first case has such water cooling potential and I am no expert in that area so that might be less than a credibal assessment.
EE
Team Canada 2010 - Starting Goalie FiXT Hockey 25 November 23, 2008 10:36 AM
1200 water cooling... starting... frosty Water Cooling 103 July 25, 2008 11:45 AM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
starting HTPC david17 HTPC Systems & Software 13 January 4, 2008 03:13 PM
