Old January 15, 2009, 01:06 PM
MorePower's Avatar
Question Looking for extension cables - 24pin and 8pin
I'm looking for 24-pin EATXPWR and 8-pin ATX12V extension cables for my P5Q Deluxe motherboard. I checked NCIX and they have some but don't know if they are any good or what gauge they are. Does anyone have any suggestions?
8-pin ATX12V..
NCIX.com - Canada's Premier Computer Store - Great Technology, Service and Selection.
NCIX.com - Buy Startech 8" Eps 8 Pin Power Extension Cable - EPS8EXT In Canada.
NCIX.com - Buy Works 8 Pin Eps Male to 8 Pin Eps Female Cable Adapter 12IN - CB-8M-8F In Canada.
24-pin EATXPWR..
http://www.ncix.com/products/index.php?sku=4053060
NCIX.com - Buy 8IN Extension Cable for ATX12V V2.0 24PIN Power Supply - ATX 24-24 pins 8in In Canada.
Thanks
Old January 15, 2009, 01:13 PM
SugarJ's Avatar
They will all do the same job. The ATX spec includes a minimum wire gauge IIRC.
Personally, I'd grab the sleeved 8pin and the black 24-pin, just because my case has a window.
Old January 15, 2009, 01:37 PM
MorePower's Avatar
I also have a window (Lian-Li V1000Z) and want to hide most of the cables but I need extensions. I want to individually sleeve each wire on the 24-pin anyway.
Old January 16, 2009, 10:40 AM
BrainEater's Avatar
Eeek.....
Sleeving ATX connectors sucks.Good luck !!
I find the molex pins on connectors like the ATX20/24 pin and the eps connectors to be very much single use....Even the ones I remove with my professional molex tools generally don't re-use well.
I am actually in the process of sourcing out ATX/EPS extensions as well , for my thinktank project....
I've only found the 8" extensions you listed : I need ones that are 24-30 inches so I'll be either having them custom made , or making them myself.
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old January 18, 2009, 11:51 PM
chouchou's Avatar
just a tip:
pricematch those extensions to ones from direct canada.
i find that NCIX markups their cables a lot more compared to DC.
i had bought 3 pin extensions that i had pricematched to 85 cents whereas NCIX sold them 2 dollars a piece regular.
3pin to 3pin fan extension cable SmogTown Air Cooling 13 January 12, 2011 12:56 PM
cables for monitors Tazer-[X] Troubleshooting 9 July 16, 2008 11:08 AM
WTB: Sata cables!! kem Buy/Sell & Trade 19 March 27, 2008 07:45 PM
DVI and Anolog Cables @ once? frosty Display Units 2 March 21, 2008 10:44 AM
4pin ATX12v and 8pin EPS connector magictorch Power Supplies 6 December 6, 2007 04:39 PM
