Old January 9, 2009, 05:44 PM
Default Building a new PC, and i need help with some things
:help:hey guys. im going to build a computer in the next month. i need to know a couple of thing:
EVGA nvidia GTX 295 Plus
6GB of DDR3 1333MHz (overclocked to 1600MHz)
EVGA X58 motherboard
Antec truepower quattro 1000W PSU (will this be enough for everything?)
Core i7 920 (want to overclock to 3.8) (how may i go about doing that?) (whats a good after market cooler for that clock and higher?)
Antec 1200 full tower case
My main use for this computer is gaming, is there anything i need to change?
I live in Toronto BTW
Old January 9, 2009, 09:20 PM
Instead of the Antec power supply get either the Corsair or Ultra 1000W. The Ultra is currently on sale at Tiger Direct. For the case take a look at the HAF. Great price along with great quiet cooling and tons of room for hiding cables. Don't get a GTX 295 unless you have a 24 inch or more monitor.
Old January 9, 2009, 09:26 PM
geokilla's Avatar
I say Corsair HX620 or HX1000, no Ultra.
Also, answer the sticky so we can help you better.
Old January 9, 2009, 09:34 PM
Well I think you're fogetting that part of what you're saying is based on personal preference...
But I'll share my knowledge/opinion...
I do agree with crazyhorse that the Coolermaster HAF is far better for cooling and cable management than the Antec 1200 (just got the HAF myself) Although it's kind of worrysome that so many people are buying this case... They're sure to start popping up at LAN parties.
The only other thing I could suggest would be to change the vid card. It pains me to say it, but right now ATI's ahead in the game (no punn intended ) when it comes to gaming and GPUs. A nice one to go with would be the ATI 4870x2. About the same price as the 295 plus and it out-performs it too.
Excellent CPU choice... Great bang for buck!
Umm with the RAM make sure to get a brand name (especially if you intend to OC it) You'll thank yourself later Corsair or OCZ are good ones to go with. G-Skill's another good one.
Good Luck!
Cheers
Old January 9, 2009, 09:39 PM
rjbarker's Avatar
Hey Geokilla...I think the above line pretty much sums it up and is more than enough!!
If you got the cash why not?....although the GTX 280 right now is a sweet deal at $349 - $400
Sure...but no guarantees you'll get that OC out of it!
- yep the same one I just ordered!
Cannot comment on this PSU as I have no experience with it nor have taken the time to "Google" it...I however have found so far that my Corsair HX 1kW has been satisfactory running 280 SLI config
The same CPU I just ordered...no idea or guarentees on OC, although as yourself I have read many getting popsitive results with this choice, personally I'm hoping for around 3.6 - 3.8 Ghz, anything more will be a bonus! EDIT: Went with the Thermaltake 120....$75 DC
Supposed to be very good for cooling and that is the main objective right?!
Anything that provides adequate cooling and room to work, as well as "nice to the eye" is what I'm after....hence the Silverstone!
In Geokillas defense, perhaps a budget??? That will help determine Case, GPU etc.....
Firestrike Extreme: 21.452
MARK 11: 32.530
Old January 9, 2009, 09:42 PM
rjbarker's Avatar
Ummmm...just wondering where you got this info from...?...the Reviews I saw here said otherwise, besides...$700 + for a 4870 x2 when the GTX 295 is available for $500+ or better yet the GTX 280 for $349 - $400.....uh...you better do a little more research their Pard!
EDIT
GTX 280 EVGA E-GEFORCE GTX 280 602MHZ 1024MB 2.214GHZ GDDR3 PCI-E Dual DVI-I HDCP HDTV Out Video Card - DirectCanada
HD 4870X2 NCIX.com - Buy Diamond Radeon HD 4870 X2 Xoc 800MHZ 2GB GDDR5 2XDVI PCI-E Video Card - 4870X2PE52GXOC In Canada. ---Wow!!! Thats actually a $50 USD MIR, your intial cost after Taxes will be $800 +...you gotta be kidding me!!!!
GTX 295 NCIX.com - Buy EVGA E-GEFORCE GTX 295 Plus 576+MHZ 1792MB 1.998+GHZ GDDR3 PCI-E Dual DVI-I HDMI HDCP Video Card - 017-P3-1292-AR In Canada.
The GTX is cheaper by about $100 or so....my mistake, but it does outperform the 4870x2 in most Game Benches...
MARK 11: 32.530
Old January 9, 2009, 09:53 PM
Cptn Vortex seems to like his X3 Ultra 1000.
JonnyGURU gave it 9.5/10. JonnyGURU.com - Power Supply Reviews and more! - Reviews - Ultra Products X3 1000W
But yeah Corsair power supplies are great.
Old January 9, 2009, 09:58 PM
rjbarker's Avatar
Yep....so thier you go!!! Thnas CHJohny for the Link!
MARK 11: 32.530
Old January 10, 2009, 05:49 PM
EDIT
Yes, but there's mixed reviews on this...
Maximum PC mag. gave the preferred choice to the 4870 x2 over the GTX 295...
NCIX.com - Buy Diamond Radeon HD 4870 X2 750MHZ 2GB GDDR5 2XDVI PCI-E Video Card - 4870X2PE52G In Canada. Yes indeed! NCIX has a rebate on this card as well! With the rebate it makes it cheaper than the GTX 295.
NCIX.com - Buy XFX GeForce GTX 295 602MHZ 1792MB 2.21GHZ GDDR3 PCI-E Dual DVI-I HDMI HDCP Video Card - GX295NHHFF In Canada. $50 more than the 4870 x2..
After getting the 4850 I have to say, I'm quickly becoming an ATI fan
Anyway, to put the subject back on thread topic, I would suggest getting the gtx 280... It's at a smokin' price right now and apart from numbers and benchmark results, you won't notice much difference in game.
Old January 10, 2009, 09:59 PM
guys, the RAM brand im getting is G-skill, or OCZ. and i have a 45-inch Samsung HDTV as a monitor. how much ram would i need to overlcock CPU too 3.6-3.8 GHz. How am i supposed to overclock anyway? what steps do i need to take, and what do i need to do on that EVGA motherboard
[FS] nothing atm HiTi Buy/Sell & Trade 114 February 1, 2016 05:30 PM
Things to see and do in Vancouver? misterd Off Topic 29 January 6, 2009 01:48 AM
21 things you can only get away with saying at Christmas Supergrover Off Topic 9 November 21, 2008 03:43 PM
Seeing if there is any interest in a few things. Sniper Buy/Sell & Trade 6 October 16, 2008 06:53 PM
Several things that I need help with.. omgwtf Networking 8 November 13, 2007 06:44 AM
