Old January 7, 2009, 10:29 PM
Default First Build - Basic
Hey everyone
I'm planning on making my first build sometime in the next month or so, and any help would really be appreciated.
It will be used for most basic things. Internet, music (I need a good sound card), cd/dvd burning, some games but nothing that's too hard to run.
I'm hoping for around $800, and if I'm able to include the monitor in this price that would be even better.
Canada! I'm not sure whether DirectCanada, NCIX or TigerDirect is recommended, so advice on which sites to use is appreciated.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Intel, and ATI or nVidia are fine.
No parts to use, sadly.
Yes, I have read lots.
I'll most likely run it at default speeds, as I'm not too familiar with overclocking yet.
In the next month or two.
Thanks again!
Old January 11, 2009, 10:01 AM
Hey, thanks for the reply! This has definitely given me some ideas...I'll post more a bit later.
Basic budget build CactusJoe New Builds 3 January 4, 2009 05:38 PM
Basic questions for a 4870 rig Bucklaz New Builds 13 December 27, 2008 01:02 AM
Can I make a basic computer with a 500budget? blogz101 New Builds 22 August 2, 2008 12:11 AM
Basic System Shredder HTPC Systems & Software 6 March 13, 2008 07:18 AM
