Old January 5, 2009, 12:04 PM
Default Is this going to work?
In order to mitigate costs for the future when the Socket 1366's come into the mainstream (and prices decrease), I want to build something less expensive now under Socket 775 and be able to swap some items for a future build. I'm hoping this present build will last 18-24 months. I'll be using the pc for games (like to play FPS like Crysis, Bioshock, Far Cry 2, Left 4 Dead, etc.) and don't need ultra eye-candy stuff....just medium to possibly high levels with playable frame rates....will also just be using internet and downloading. Budget, including monitor would preferably be around $1,000 or lower, and I won't be OC'ing. My choices are as follows, and please excuse my ignorance around compatability:
-Samsung 2253 BW 22" monitor
-CM 690 case
-Corsair 750TX W power unit
-Sapphire 4850 HD 512 MB DDR 3 graphics card
-Intel E5200 CPU
-WD Caviar Black 640 GB 32MB hard drive
-Asus P5KPL-CM Matx Intel G31 LGA775 1PCI-16 1PCI-E1 2PCI SATA2 Video Sound Gblan Motherboard
-Samsung SH-S223F/BEBN 22x Speedplus DVD Writer OEM
-RAM - not sure what to get....2 or 4 GB?
I'd like to use the case, power unit, DVD writer, and hard drive for a future 1366 build, and hopefully the graphics card as well (perhaps even do a cross-fire). Will this present set-up be okay...especially in relation to the motherboard, and what memory recommendations can you make? I'm not a fanboy of anything in particular even though my current ATI graphics card and Asus motherboard have been problem-free for the past 4 years. I'm open to any and all suggestions.
Thanks so much!
Will This Work? Infiniti Video Cards 2 July 21, 2008 11:54 AM
will this work Jhayman O/S's, Drivers & General Software 1 July 3, 2008 12:59 AM
TAT will not work. yycraven Troubleshooting 13 February 14, 2008 08:49 AM
Will this all work? Infiniti Water Cooling 11 January 8, 2008 10:50 PM
how does RMA work? vblanche CPU's and Motherboards 4 July 24, 2007 10:36 AM
