Old January 6, 2009, 07:55 PM
ebdoradz's Avatar
you can take a look at my TT armor water setup
http://www.hardwarecanucks.com/forum...html#post77710
not exactly like your case but i found that a rear mount setup is the easiest way of doing it and it leave you lots of space inside de case
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old January 7, 2009, 01:23 PM
element291's Avatar
sub'd for later. Looking forward to seeing your setup! :)
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Old January 7, 2009, 08:43 PM
metalcore's Avatar
Just finished my water cooling set up!
Going to take some pics and post it later this week.
I ended up installing the rad at the back of the case.
_____________________________________
-Cooler Master HAF X
-Asus Crosshair V
-SAPPHIRE 4890 " CROSSFIRE"
-Corsair H60
-OCZ VERTEX 2 60GB
-Phenom II 955 black
-wd velociraptor 300g sata hd
-wd caviar black 750gb sata hd
-wd caviar green 1000 sata hd
-8gb (2x4) GSKILL RAM
-lg blu-ray drive
-asus dvd/cd drive
-enermax galaxy 1000W PSU
-Kingston card reader
-Windows 7 Ultimate 64bit
Old January 7, 2009, 08:46 PM
metalcore's Avatar
I ended up installing the rad at the back of the case the same way you did. Works very well but I had to change the internal air flow a little( from bottom to top).
Thanks for your help!!
-Asus Crosshair V
-Corsair H60
-OCZ VERTEX 2 60GB
-lg blu-ray drive
-asus dvd/cd drive
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
SLI Water Cooling. BALISTX Water Cooling 5 March 19, 2008 10:02 AM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
