Old December 24, 2008, 11:14 PM
LCB001's Avatar
Folding Captain
Originally Posted by Hermes、 View Post
mhmm, thanks for the advice, I guess I will have to work with it. Just one thing though, can the Antec 300 fit an 9800 GTX+ SLI as well as an aftermarket cooler such as the Vendetta 2? Also, could the 610W PSU I selected be able to power it all up?
The Vendetta2 will fit fine even with the optional side fan as will the 9800GTX+. You will just have to fit your HDD in the right spot. The silencer should be fine with the GPU's as well. With a Zalman ZM-F3 fan on the side and in the bottom front slot my GPU dosn't break 60* and my HDD is usually around 26* and mine Folds 24/7. See 1st rig in sig...
Edit; I can put up a pic if you want...
Folding For Team 54196
Old December 24, 2008, 11:46 PM
Great stuff guys, thanks. Now the only thing I need to figure out is if it is safe to run SLI 9800 GTX + using a 610W PSU from PC P&C
Old December 24, 2008, 11:57 PM
Chilly's Avatar
It's pushing it a bit but, you should be plenty safe.
Old December 25, 2008, 12:01 AM
LCB001's Avatar
Folding Captain
The silencer 610 will run those easily. If you check Sky's review on the GTX+ his system used 162w at idle and 248w loaded and that was with a highly OC'd QX9770 quad. Adding a second GTX+ might bring your max draw up to ~375w at most 400w. If you check I think the recommended PSU is only 475w for SLI...
Old December 25, 2008, 12:15 AM
Mhmm, alright I will check it all out. What is, in your opinion, the bet operating system to use? Also 32 bit or 64 bit?
Old December 25, 2008, 12:18 AM
LCB001's Avatar
Folding Captain
I use Vista Home Premium 64 bit on both my rigs and have had zero problems...
Old December 25, 2008, 12:22 AM
mhmm, alright thanks. I checked out all my parts, so tomorrow morning when they open I will order. :)
Old December 25, 2008, 12:40 AM
Chilly's Avatar
On a fresh, new install, might as well go the 64bit route, it works great, very few, if any issues compared to the 32bit edition.
I Have Made Upgrade Linus CPU's and Motherboards 1 November 14, 2008 02:05 AM
It's almost as if they were made for each other Dr_BenD_over Video Cards 4 October 5, 2008 05:04 AM
The best 'build' I've ever made....so far! Prof. Dr. Silver New Builds 26 July 19, 2008 08:34 PM
Where are GPU's made? magictorch Video Cards 4 May 27, 2008 08:19 PM
NVIDIA 8800 Ultra Proves to be a Tragically Arrogant Mistake Beermaster Press Releases & Tech News 5 May 4, 2007 06:17 PM
