Old December 22, 2008, 12:29 PM
Level up: 73% Level up: 73% Level up: 73%
Level: 11 - 94 points to level up
Default Basic questions for a 4870 rig
All questions answered
Thx for the help everyone :D
Old December 22, 2008, 12:55 PM
paphman910's Avatar
Level up: 27% Level up: 27% Level up: 27%
Level: 10 - 207 points to level up
I would suggest Gigabyte GA-EP43-DS3L motherboard as the SATA connectors won't be covered up by the graphics card and I think it is pretty cheap priced board for intel E5200 but you could wait until after the new year when prices will start to drop due to AMD Phenom II coming out.
Paphman910
Paphman910:
(PC Power & Cooling Silencer 610) (Asus P5K-E/WiFi-AP) (Xeon E3110) (G.Skill 4GB DDR2-6400 800) (8800GTS 512 MB) (Seagate 500GB) (Pioneer 212D DVD Burner).
Old December 22, 2008, 12:58 PM
stoanee's Avatar
Level: 18 - 644 points to level up
I have a E3110@4 ghz/4870/2 hdd/1 dvd/2 hsf/3 case fan/2x2gb ram and it rarely draws more than 300 watts. I think you could get away with a 450. Calculate here.
http://http://web.aanet.com.au/SnooP/psucalc.php
Also here is a quote from wikipedia:
"Computer power supplies are generally about 70–75% efficient.[2] That means in order for a 75% efficient power supply to produce 75 W of DC output it would require 100 W of AC input and dissipate the remaining 25 W in heat. Higher-quality power supplies can be over 80% efficient; higher energy efficiency waste less energy in heat, and requires less power to cool as a result. As of 2007, 93%-efficient power supplies are available.[3]
It's important to match the capacity of a power supply to the power needs of the computer. The energy efficiency of power supplies drops significantly at low loads. Efficiency generally peaks at about 50-75% load. The curve varies from model to model (for examples of how this curve looks see the test reports of energy efficient models found on the 80 PLUS website). One rule of thumb is that a power supply that's over twice the required size will be significantly less efficient, and waste a lot of electricity."
Old December 22, 2008, 01:03 PM
Paphman910
Oh man, I was waiting all this time until boxing day. I think I might just bite on boxingday, since i've already got the card
Originally Posted by stoanee View Post
I have a E3110@4 ghz/4870/2 hdd/1 dvd/2 hsf/3 case fan/2x2gb ram and it rarely draws more than 300 watts. i think you could get away with a 450. Calculate here.http://http://web.aanet.com.au/SnooP/psucalc.php
Seriously? jebus, why in the heck would diamond reccomend a 500-700w psu. probably compensation for the market of lower efficiency psu's i suppose.
Also, thank you for the site. I'll check it out right now :)
edit: just checked the site. so the 450vx is 83% that should be plenty for my needs :D So I should mainly be looking at the wattage after efficiency. In the 450vx's case its usable wattage would be 360w right?
This is a neat lil site. Thx again
Old December 22, 2008, 01:56 PM
SugarJ's Avatar
Level up: 71% Level up: 71% Level up: 71%
Level: 20 - 323 points to level up
Nope. Sorry. A PSU's rating is its output rating. So a 450w PSU will put out 450w to the system, but draw more from the wall (like 562w if it's an 80% efficient PSU).
Intel i7 920 EVGA X58 Classified Asus GTX285TOP, Xonar DX Silverstone TJ07 "Murdermodded", Strider 850W OCZ Vertex
WC Loop: Heatkiller 3.0 MCP655 Feser 360 EK 150 Res
Old December 22, 2008, 02:28 PM
ooh ok, gotcha
Old December 22, 2008, 07:25 PM
geokilla's Avatar
Level up: 96% Level up: 96% Level up: 96%
Level: 19 - 43 points to level up
If you're broke, then why the hell would you get a 4870? There's no point in getting one if you're not gonna spend like $600 on the other parts of your PC. Your other components, such as the CPU will bottleneck the 4870 unless you overclock say, a E7200 to at least 3.6Ghz.
Assuming by broke you mean you're only gonna spend $300 on your PC, I say go with a AMD dual core rig. Those will serve you well for a budget system.
Old December 22, 2008, 10:45 PM
thx for the reply. So I'd need atleast an E7200 oc'd to 3.6 to not bottleneck the card?
that's nuts. so there is no stock processor out right now that can allow a 4870 to run unhinderered?
Old December 23, 2008, 03:45 PM
5ILVgeARX's Avatar
Level up: 50% Level up: 50% Level up: 50%
Level: 18 - 443 points to level up
i believe most e5200 can reach 3.6ghz
why not get the e5200 and put a little more for a good overclockable board.
Originally Posted by Perineum View Post
Eventually we all learn to STFU unless we're ready to debate.
Heatware
Old December 23, 2008, 07:06 PM
LOL funny that you said that. Cuz I changed the board for a better oc board, a p43. But I also changed the psu to a 400w psu, I think that will probably limit me now haha.
Old December 23, 2008, 07:36 PM
geokilla's Avatar
A 400W on a 4870 is too risky. I would get at least a good 500W PSU to power that rig. In the end, your 4870 rig is un-doable. Either sell it back out, return it to FS, or save up.
Old December 24, 2008, 08:06 AM
mlauzon's Avatar
Level up: 61% Level up: 61% Level up: 61%
Level: 10 - 110 points to level up
Originally Posted by Bucklaz View Post
I was thinking of using NCIX to pricematch other e-tailers on boxing day, but I'm not sure if they would pricematch boxing day specials.
They won't, etailers & brick-and-mortar will not price match on BD.
Michael
Intel Core i7 965, ASUS Rampage II Extreme, G.SKILL Pi Black DDR3-1600 PC3-12800 6GB CL 8-8-8-21, Sapphire Radeon HD 4870 X2, Samsung Spinpoint F1 1TB (2), LG GH22NS30 DVD Writer, Corsair HX1000W, Windows Vista Home Premium x64, Cooler Master HAF 932, Samsung SyncMaster 245T, Razer Lycosa Mirror, Razer Lachesis Wraith Red, Razer Destructor
Old December 26, 2008, 07:42 AM
b1lk1's Avatar
Level up: 94% Level up: 94% Level up: 94%
Level: 18 - 60 points to level up
Then explain to me why my ENTIRE system including 2HD's and a watercooling loop, 6 fans and all my overclocked hardware only pulls 290W through the wall socket as measured by a Kill-A -Watt? Do yourself a favor and stop over-guess-timating power needs as there are too many other people that already have that job.
I agree that a 400W is the lower limit for a 4870 based PC, but it will be fine.
Old December 27, 2008, 12:02 AM
nice... lol, I was kinda getting worried about my build
CPU: E5200 @3.5ghz 1.232v [12.5*280](stock hsf)
MOBO: Biostar TP43D2-A7
VID: Diamond HD4870
HDD: Seagate Barracuda 7200.10 500gb
RAM: G.Skill 4GB @ 576mhz (4.4.4.12)
PSU: Seasonic SS-400ET
Can I make a basic computer with a 500budget? blogz101 New Builds 22 August 1, 2008 11:11 PM
PSU for SLI Questions. Milt Power Supplies 9 July 2, 2008 03:20 PM
basic(?) psu question - dual rail combined ratings ccm001 Power Supplies 7 March 26, 2008 04:58 AM
Basic System Shredder HTPC Systems & Software 6 March 13, 2008 06:18 AM
