Old December 17, 2008, 01:02 PM
Default ThermalTake Armor+ or Cooler Master Cosmos S Case
hey guys, im going to start building my new rig in the next couple of weeks and the gf wants to buy me a case for xmas, so really needs to order tomorrow, but I am undesided about which to go for, ThermalTake Armor+ or Cooler Master Cosmos S Case. I will be using it for a high spec qued core machine, which i am looking to swap over to part water cooling in march/april, the main things im looking for is good build as i want to use this case for 5-6 years with manly parts being changed, and something that looks good, that why i first started looking at the amour plus because of the large side window. anyways anyone on here have one of these cases? any views on which to get?
Old December 17, 2008, 01:27 PM
Cosmos S hands down, the Armor+ doesn't stand a chance..
Old December 17, 2008, 01:33 PM
have you used both cases?
Old December 17, 2008, 01:40 PM
Soultribunal's Avatar
Ahhh the Venerated Armor+ Case.
I have never used a Cosmos Case, although I know Coolermaster is starting to really make some nice CAses (see HAF 932).
If you have to choose between the two, I can only suggest the one I've used. That would be the TT Armor + . I've downgraded (well, size at least) to an Apollo Now.
The Armor is an old Design, and like a lot of other cases it has lots of things done right, and somethings that make you question what TT was thinking.
I'll probably get a lot of Flak for saying TT but I did love that case, for better or for worse.
Hopefully someone who has used the Cosmos will let you know their take on it. Afterall it might be the better of the Two for what you need.
Good Luck.
ST
www.realhardwarereviews.com
Old December 17, 2008, 01:50 PM
rjbarker's Avatar
Whats your budget???
+1 Silverstone!
NCIX.com - Buy Silverstone Temjin TJ09B-W Black E-ATX Case 4X5.25 1X3.5 6X3.5INT No PS W/ Window - TJ09B-W In Canada.
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old December 17, 2008, 01:52 PM
I'm going with miggs on this...
The Cosmos S has a bunch of room and can easily support a 120.3 internally without any modifications, take a look at the worklogs forum...
[edit]http://www.hardwarecanucks.com/forum/cases/5290-coolermaster-cosmos-s.html[/edit] -- No Mod 120.3 rad
Its definitely a beast of a case, CM makes quality stuff
Def the Silverstone over the CM tho if its in the running
CM690 - Asus P5Q-E - Intel E8400(E0) @ 3.6 - OCZ GameXStream 700W - Swiftech Apogee GT (Bowed) - 2x2GB Mushkin Redline PC-8000 - EVGA GTX 260 - Samsung 226BW
Old December 17, 2008, 02:01 PM
Im uk based, about 140, dont really want the other half spending more then that
Old December 17, 2008, 02:05 PM
EaGle1337's Avatar
is the haf in your price range?
Old December 17, 2008, 02:20 PM
rjbarker's Avatar
That HAF 932 really caught my eye prior to purchasing the Silverstone.....it looks like it can cool incredibly well and I thought the Review of it here on HC was very positive. I think if I were looking at a Case with a Budget not quite up to the Silverstone or Lian Li requirements I'd be very tempted to go with that HAF!
Timespy: 18.613K
MARK 11: 40.185K
Old December 17, 2008, 06:57 PM
I'm thinking it would be because for us in Canada, it is actually cheaper than the Cosmos S, so technically speaking I would believe it would be in the UK as well.
Cooler Master HAF 932 Case no_pulse Cases 7 September 3, 2008 03:35 PM
Comment thread for Thermaltake Armor+ MX Mid Tower Case Review AkG Cases 1 June 13, 2008 08:52 PM
Thermaltake VH6000BWS Armor+ Full-Tower ATX Case Review? frosty Cases 2 May 3, 2008 04:38 PM
