Old December 4, 2008, 08:51 PM
Default Opinions/Advice for a $1000 build
"gone"
Old December 4, 2008, 08:59 PM
BT!'s Avatar
BT! BT! is offline
if your not in a hurry and will have time to jump on deals as they happen, i'd wait until boxing-day. best thing to do is read the reviews, you'll know better what you want/like then anyone else. :)
Old December 4, 2008, 09:18 PM
geokilla's Avatar
Ditto. Can you answer the sticky as well? It'll help us with your build.
Now off the top of my head.
Intel Q6600
ASUS P5Q Pro
OCZ/Patriot/Corsair/Mushkin 4GB DDR-800 RAM
WD/Seagate/Samsung 640GB
NVIDIA 9800GTX+ or GTX260 or ATI 4850
Corsair 520HX or 620HX
Old December 4, 2008, 10:11 PM
Intel Q6600
ASUS P5Q Pro
thanks for the setup
well .. I'm not going to be doing any OC
If I want build one with the i7 (will reconsider the budget), will it be worth it or its not necessary
Thanks
Old December 4, 2008, 10:16 PM
geokilla's Avatar
For $1000ish, definitely not worth it. Just the CPU and X58 motherboard would cost at least $600.
Old December 4, 2008, 10:45 PM
so, I will be better off with the Q6600, than E8400??
Thanks
