1. What
YOUR PC will be
used for. That means what types of
tasks you'll be performing.
work, surfing, games, video editing, photoshop
2. What
YOUR budget is. A
price range is acceptable as long as it's not more than a 20% spread
$750
3.
What country YOU will be buying
YOUR parts from
Canada
4. IF
YOU have a
brand preference. That means, are you an
Intel-Fanboy,
AMD-Fanboy,
ATI-Fanboy,
nVidia-Fanboy,
Seagate-Fanboy,
WD-Fanboy, etc, etc, etc, you get the picture.
intel
5. If
YOU intend on
using any of
YOUR current parts, and if so, what those parts are.
cd drive, dual 22" lcd's, mouse/keyboard
7. IF
YOU plan on
overclocking or run the system at
default speeds.
probably overclock
8.
WHEN do you plan to build it?
as soon as i get the parts
So far i have:
Thermaltake Wing RS 100 Piano Black ATX Mid Tower Case Intel Core 2 Duo E8400 Seagate Barracuda 7200.10 250GB Asus P5KPL-CM G.SKILL F2-8000CL5D-4GBPQ Diamond Radeon HD 4850 Coolermaster Extreme Power Plus 460W ATX Power Supply
Total $665.95
Missing os
