Originally Posted by Sniper Looks like a good setup. I'd not go cheap with your ram though. Get the best you can or at least go with 2Gb sticks if you don't want to go faster timings. You won't be disappointed If you did I don't think.
What are you going with for case,hdd ect? |
I doubt I'll be able to fit a 6GB kit into my budget, since I already reached my budget.
Also, for case, I bought the MM H2GO from TerenceJ, so I'll be using that.
As for the HDD, since I'm already tight on budget, I'm going to be using some old IDEs for the time being, until I get more money to afford a good hard drive.
Originally Posted by Chilly I agree with sniper about the ram, at least try to fit a 6GB kit kit in your budget, DDR3-1600 as well. As for the heat sink, its an excellent choice, I hear nothing but great things about the Ultra 120(the TRUE is one of the best air coolers around). I'm also assuming your gonna reuse your case HDD and etc correct? If thats the case other than the ram your build looks excellent, good choices all around.
That being said if you can't fit it in your budget for a 6GB kit, the 3GB kit will serve you very well in the meanwhile.
Don't forget to load rosetta up on it once you build it  |
Well, obviously I'll load rosetta up, I'm officially addicted right now, since this build is mainly for folding. And I guess a... little gaming..
