Old November 26, 2008, 09:59 AM
Shadowmeph's Avatar
Default IS it possible to build a lap top?
I am wondering if it is possible to build a laptop and if so what and where to purchase the parts for it. I did a search in Google but didn't really find anything
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old November 26, 2008, 10:33 AM
sure you can here's a good start DIY Laptop/ Notebook Computer-Do It Yourself Asus Laptop Computer ASUS Notebook Barebone Picture Tutorial-Best Computer Online Store Houston Buy Discount Prices Texas-Directron.com
google barebones laptop :)
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old November 26, 2008, 10:40 AM
joeperson's Avatar
Good question now should be is it worth it?
Q6600 3.0GHZ (9x333) stockV | ATI 5850 | OCZ Platinum 4GB PC2-6400 DDR2 5.4.4.15 1.9V | Silverstone Raven RV01 | Gigabyte EP45-DS3R
Corsair Professional HX750W | Windows 7 | Crossbow mounted Xigmatek HDT-S1283 | LG W2242TQ-BF 22" | Samsung 2253BW 22"
Old November 26, 2008, 11:33 AM
Jon_di2's Avatar
Usually you can find a pre-built one that is less expensive then putting it together yourself... but if you build from old parts... etc... It's possible to build for less. But even then, how much will you save? and no warrenty.
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old November 26, 2008, 01:24 PM
Shadowmeph's Avatar
well there are two reasons I want to do this the first is that I can't afford to just go and buy one, and second it is also a learning experience for me
Folder :
Old November 26, 2008, 02:30 PM
I wonder if I can turn my atx mobo into a lap top:P It would be big and bulky, like maybe a russian design?
Acer 5920G ( Stock Air ) no OC:P
At least its DX10!
Old November 26, 2008, 02:46 PM
JD JD is offline
I see 15.4" laptops go for $500 (or less) on sales or at Walmart/Sam's Club. If you can't afford a pre-built laptop, there's no way you can DIY for less money.
OCZ has barebone laptops but they run pretty close close to $1000 without processor/RAM/hard drive. OCZ Technology | Products | DIY Notebooks
Old November 26, 2008, 04:24 PM
Thund3rball's Avatar
Agreed with whoever said this, if you can't afford a prebuilt there's no way you can afford to DIY. What kind of laptop are you looking for? If you just need something for email/internet/word you can get away with a decent used P4 or Celeron M laptop for ~$300, or a P3 for even less.
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old January 11, 2012, 09:51 PM
groundwire123's Avatar
I to am going to be building a custom laptop (barebone system) and looking to order from "RK Computers". They don't have much of a selection but what they do have is very nice. However they are quite expensive. supporting nothing less (from their current selection) than an Intel Core i3 or higher. In my case, this is fine. the barebone system with the cpu and ram purchased either with the barebone system (this is an option) or seperatly, it can cost no less than $1200 USD. So if your willing to spend the money, than yes, it is possible. But really, it's easier just to go with a per-assembled one and upgrade it.
the one and only,
groundwire123
Old January 11, 2012, 11:29 PM
bigFOIG's Avatar
Was going to mention "Barebone Laptops" as well. Read up about it a long time ago, as I had the same idea as you. Never got around to doing it because yeah, it ends up being more expensive and not worth it. Not to mention that the cases the "barebone laptops" come with don't usually look very pleasant.
