Old November 23, 2008, 07:16 PM
Default Need help new build under way!!!
I got the case Cooler Master HAF 932, the PS Cooler Master Real Power Pro 650W, and the LCD monitor LG W2242TQ-BF, 22".
Obviously I need all the important stuff. I have a few options for the rest of the hardware.
Motherboard < $200
Asus P5Q-E , OR Gigabyte GA-EP45-UD3P, OR Gigabyte GA-EP45-DS3R
CPU < $250
Intel Core 2 Quad Q6600 Quad, OR Intel Core 2 Quad Q8200 Quad
Memory ~ $100
OCZ (OCZ2RPR10664GK) DDR2 PC2-8500 1066 MHz Reaper HPC Edition 4GB $87.99
OR
OCZ (OCZ2P10664GK) DDR2 PC2-8500 1066 MHz Platinum Series 4GB after MIR $79.99
OR
Corsair XMS2 Dominator TWIN2X4096-8500C5DF Matched Pairs 4GB after MIR $117
HD < $100
Hitachi Deskstar 500GB 3.5" SATAII 7200rpm 16MB
OR
Seagate Barracuda (ST3500320AS) 7200.11 SATA NCQ 3.0Gb/s 500GB 32MB
OR
Western Digital Caviar Black (WD5001AALS) 500GB SATAII 7200RPM 32MB
DVD-Drive <$50
LG G-H20L-S10 /Black
GPU < $350
BFG GeForce GTX 260 OC MAXCORE OR Sapphire ATI RADEON HD 4870 512MB OR Sapphire ATI RADEON HD 4850 1024MB
I need reviews and opinions?
Prices from Canada computers I am buying directly from a store(IN TORONTO)!!!
I also need OS at the lowest price posible.
Old November 23, 2008, 07:34 PM
Dashock's Avatar
Alright i know most people would suggest spending money on the Intel CoreI7 but the problem i see right now is one prices are wayy too inflated right now. What i mean by that is the deals which were there about 2-3 months ago on the gear you are buying were a lot cheaper. Seriously i would not want to be in your position for example the Asus P5Q-E is what i bought i love the board i paid 163 and now ncix has it at 193.
The Seagate 7200.11 500gbs are solid im running 3 of them in this house and none have been sent to warranty yet. As much as i would like to say spend the extra on CoreI7 the cost of the ram is wayy too much for the decent kits and motherboard so if your mind is set on the old and grab a good deal unfortunetely your out of luck as all the good deals are gone from the old line of products.
My recomendations
Motherboard=Asus P5Q-E
Cpu=I would go with one of the newer 45nm Quad cores your probably going to be using this build for awhile.
Ram= Go with Ocz or Mushkin. The Reaper kits are decent i got them on my brothers Amd build i got the Redline Ascents love em.
Hard Drive- Seagate 7200.11 500gb
Dvd Drive/Burner i got the same LG sata one i think its the same model you mentioned its solid. Have not had a mess up yet.
Gpu= Really up for grabs here im biased to Nvidia so the 260 is great but i think theres new gpu's coming out or revisions so id wait and grab a deal.
****You forgot to mention Cpu cooler the stock cooler is shiat.
Get the OCZ Vandetta 2 their cheap but solid.
Hope i have helped.
P.S save your money and dont buy from store in Toronto shop online at NCIX. I used to build a lot of computer back in the day and get special deals with warehouses in Toronto/Mississauga. But 9-10 Ncix would beat it. Seriously i think they accept Debit so please shop Ncix and save PST. :)
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old November 23, 2008, 10:27 PM
cwestwell's Avatar
I second Dashock's verdict..
- The P5Q-Pro is a decent alternative if it is cheaper where you are shopping...
- Maybe the Seagate 640GB it is nearly the same price...only if available though.
- I would search for a steal on the 4870 don't pay over $290 otherwise get a GTX260 core 216 either way both cards will support dual cards in the next gen boards..so by the time comes to get another card you would likely be looking at a new mobo and CPU anyway.
- I am a fan of the WD black edition HD's but I do not have one so I cant provide much merit besides that the specs make me drool.
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
Old November 23, 2008, 11:55 PM
Sapphire ATI RADEON HD 4870 512MB ----------- $294.99
Canada Computers - Video Cards > PCI-Express Cards > Powered By ATI : Sapphire ATI RADEON HD 4870 512MB GDDR5 Dual Dual-Link DVI HD Audio Shader Model 4.1 800 stream processor PCI-Express 2.0 Graphics Card.
The prices at Canada Computers are very good some times better than NCIX and I can have it on the spot.
Old November 24, 2008, 12:02 AM
TNX for the tips I will go with the Asus P5Q-E {http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=018815&cid=MB. 157}
Any recommendations for an optical drive?
CPU cooling I considering the vendetta 2.
Old November 24, 2008, 01:36 AM
Dashock's Avatar
Cant wait to see the build and watever puppy you decide to put in there i hope you join our Folding team. Join the fight!
Asus P5Q-E
Corsair Cx600M
Old November 24, 2008, 07:41 AM
Chilly's Avatar
Motherboard - P5Q-E
CPU - Q6600
Memory - 4GB (2x2GB) OCZ Reaper PC2-8500
HD - WD Black 500/640GB, go for the 640GB edition if you can.
GPU -ATi 4870, 1GB if possible
Only choices I'm gonna explain is the GPU and CPU. Go for the Q6600 because the extra cache you gain over the Q8xxx series WILL gain you better performance. Don't buy in into the 45nm hype, while most of the 45nm chips ARE better, the Q8xxx series is not. As for eh GPU, try and get the 4870 1GB version, the extra ram will help out lots when you try to crank that AA up. That being said the nVidia 260 GTX 216 Core is also a very nice card, if you can't find/get a 1GB version of the 4870, take a serious look at the 260GTX.
Old November 24, 2008, 11:10 AM
BALISTX's Avatar
You can price match that price at NCIX and still save on the PST.
Heatware
HWBOT
Old November 24, 2008, 05:25 PM
EVGA E-GEFORCE GTX 260 Core 216 Ordered NCIX.com $308.88
GPU is underway.
