-   -   Maybe a Future Build. (http://www.hardwarecanucks.com/forum/new-builds/12071-maybe-future-build.html)
BALISTX November 21, 2008 08:08 PM
If I scrounge my pennies I might be able to pull one of these two builds out of my @ss.
EVGA nForce 750i SLI - $157.56
Intel E5200 - $101.78
Corsair TX650W - $112.17
G.Skill F2-8000 4GB - $63.02
EVGA GeForce 9600GT - $120.96
LG 22x DVD-RW - $25.99
Xigmatek RS1283 - $41.04
Xigmatek ACK-I7751 mounting kit - $9.72
Total: $632.24
Keep in mind this build, I do have another 9600GT that I will be running in SLI. This 750i mobo does 8x SLI.
I will be OCing the processor to 3.6GHz
Biostar G31-M7-TE mATX - $57.51
Intel Core 2 Duo E8400 - $198.88
Powercolor Radeon HD 4850 512MB - $214.92
Corsair VX450 - $82.53
$630.59
This build I will not be overclocking.
All prices from Direct Canada.
Which build do you think I would get better performance out of?
geokilla November 21, 2008 09:10 PM
The latter has my vote. But since you're not overclocking, just use whatever coolers you got left around? I don't know the members well, but I swear you got extra coolers lying around somewhere....
And since you're not overclocoking, why would you use PC2-8000 RAM? Just run at 1:1?
BALISTX November 21, 2008 09:15 PM
The price was a steal for 4GB. I do have an AC Freezer 7 Pro lying around that I can use a bolt-thru kit on. Lets not talk about bolt-thru kit. Finding them in stock is a hard thing to due.
1Tanker November 21, 2008 09:21 PM
Yeah...i agree with geokilla. I would take system 2...drop the Xigmatek(since you're not overclocking), and save $50...or add it towards a better mobo or PSU. Then in the future...when you decide you want to release the Wolfdales' potential.. grab a good aftermarket HS/F...and have fun overclocking. :biggrin:
BALISTX November 22, 2008 02:26 PM
Biostar TP43D2-A7 - $91.26
Intel E7300 - $145.99
G.Skill F2-6400 4GB - 60.78
XIgmatek HDT-RS1283 - $41.04
Xigmatek ACK-I7751 - $9.72
Corsair VX550W - $60.00
LG GH22Ns30 Black - DVD+RW - $25.99
Total: $434.78
I will be using my 9600GT for now and just save up some money to upgrade the card.
Goal is to get the process to 360x10 FSB
If I set the memory up to 1:1 it should run the memory at 720MHz correct.?
geokilla November 22, 2008 03:37 PM
Memory speed will be at 720Mhz.
Assuming what you posted with the E7300 is a new build, why not get a E7200 instead? I was able to get 3.7Ghz on my E7200 ^^
1Tanker November 22, 2008 03:38 PM
Total: $434.78
Correct. :thumb:
BALISTX November 22, 2008 04:39 PM
It's only a $15 difference and I like the 10x multi instead of the 9.5x multi. If I got the E7200 I hate using .5 multi so I would put it to 9 and in order to get 3.6GHz I'd have to put the FSB to 400 where I'd rather play it safe and have the FSB at 300. However if I did get the E7200 and ran it at a 1:1, I would be getting the most out of the memory.
Decisions, Decisions.
I'll have to do some more research to see if that board can hit 400 FSB.
geokilla November 22, 2008 08:11 PM
Well, I think most E7XXX CPUs would max out at around the 3.8Ghz mark. Some lucky ones could get to 4Ghz too, and this is done on a E7200. If my E7200 had a VID of 1.15V instead of 1.2V, I think I could push it up to 4Ghz.
And what's so bad bout the .5 multi?
1Tanker November 22, 2008 09:29 PM
I would be quite surprised if that mobo couldn't run 400FSB, as the vast majority of P45 boards(and a lot of P35) will run 500FSB. I don't think that P43 is that much different, from a performance standpoint.
