Originally Posted by geokilla Following changes would be made for me:
PSU: Corsair HX620
RAM: Mushkin, Corsair, OCZ, etc. 4GB DDR-800 4-4-4-12. Can easily get to DDR 900, which means 450FSB if you run at 1:1 ratio
CPU: Q9450 or Q6600
Hard Drive: WD 640GB Black
Monitor: Acer 22". I believe it's around $180 at Staples.
CPU Cooler: OCZ Vendetta 2
Video Card: NVIDIA GTX 260 or GTX 260 Core 216 or ATI 4870 1GB Those are the best bang for buck imo. No need for 4870X2 since you'll be using 1680X1050 resolution.
Don't forget to check out NCIX as well. They have weekly specials. And don't forget to use the price compare feature found at the top of the forums. Other than that, have fun gaming! |
PSU: any reason to get the corsair? The 850w ocz gamexstream is the same price basically.
Ram: I am new to this, can you explain "Can easily get to DDR 900, which means 450FSB if you run at 1:1 ratio" so that I might understand the benefits?
CPU: Not plannign on doing much overclocking, and the 9550 is about the same price as the 9450.
DO I need a cooler right away that isin't the stock one or can I upgrade later if I want to overclock then?
Thanks. I was going to go ncix for a while but direct canada is cheaper in a good number of areas.
Balistx: Will a modular psu actually help a lot?
Is the drive you guys are talking about this:
Xpress Canada - Hard Drives > Desktop Drives > 3.5" SATA Drives : Western Digital Caviar (WD6400AAKS) 640GB SATAII 7200RPM 16MB Buffer (OEM).
