Old November 20, 2008, 09:20 AM
there could be stuff on the HDD, it should be formatted ?
Old November 20, 2008, 09:28 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Have you plugged in the PC speaker onto the mobo. Not your actual sound speakers but the diagnositc speaker which plugs in near the On and Reset connectors on the motherboard?
Old November 20, 2008, 09:29 AM
sswilson's Avatar
Did you reset the cmos yet? You mentioned trying to "get to the cmos", but didn't say if you used the jumpers on the motherboard to reset the cmos to default.
Old November 20, 2008, 09:44 AM
Is this the AC'97 or the HDA?
I still have no sound whatsoever from the internat speaker
Old November 20, 2008, 09:46 AM
Yes I did! :)
The RAM AND the HDD were the problem.
I managed to start the comp, now I can enter the bios.
Everything seems to work... but the internal speaker...
all i need to do now is install my OS, i'll keep you guys updates
thanks tons for the help!!
Old November 20, 2008, 09:48 AM
SKYMTL's Avatar
Let's put it this way: the small speaker on your case which is supposed to go "beep" when you turn your computer on...
Old November 20, 2008, 09:57 AM
I cant find it..
Grrr...
I browsed trought the user manual and there is nothing about the internal speaker for the antec 300... I know exactly what you are talking about... its weird, how can it be missing?
Anyone else has an antec 300?
Old November 20, 2008, 10:41 AM
SugarJ's Avatar
Gigabyte boards don't come with the little speaker, and Antec doesn't usually send them with the cases. I scavenged one out of an old system, or you can pick one up for a couple of bucks at your local PC store.
  #19 (permalink)
Old November 20, 2008, 10:49 AM
3.0charlie's Avatar
Confirmed for both Gigabyte and Antec. The 300 does not have an internal speaker.
Hydro-Quebec is salivating...
  #20 (permalink)
Old November 20, 2008, 05:51 PM
Hey guys!
I managed to start the cpu, install the os and everything and it works!
Well, it works besides two things.. dang, again!!? :)
1- There is 2 audio (microphone and headset) pins on the front of the computer, antec 300's case. Im not getting any sound from when my headset is plugged in. Could this be due to a wrong connection to the motherboard? There was some negative and positive pins to insert in the motherboard from the case. Maybe i plugged them in upside down?
EDIT : The random crashness was due to a major fail from the uber old videocard
thanks alot guys,
you are all great
thanks tons
