Old November 5, 2008, 09:07 PM
kav kav is offline
Default Help with wiring - again newbie
I've got most of my parts and have installed them in the case. The hardwear was easy to install but I have no idea how to wire up all the components and case. I'm reading the mobo instructions but am seriously lost! Please help!
Old November 5, 2008, 09:15 PM
BALISTX's Avatar
First off what motherboard do you have?
Second as for cable management zip-ties are your friend.
Heatware
HWBOT
Old November 5, 2008, 09:25 PM
kav kav is offline
I have the asus P5Q Pro.
The wire management is something I am okay with. It is figuring out what goes where on the mother board...
Old November 5, 2008, 09:29 PM
BALISTX's Avatar
If you are trying to figure out the front connectors, the board should have come quit the Q Connectors also called Quick Connectors.
Heatware
HWBOT
Old November 5, 2008, 09:30 PM
BALISTX's Avatar
YouTube - ASUS Q Connector
Heatware
HWBOT
Old November 5, 2008, 11:05 PM
kav kav is offline
I think I am done. I just plugged it in if it fit! :)
I'm going to turn her on and do the configuration tomorrow..
BALISTX's Avatar
awesome.
Heatware
HWBOT
Old November 6, 2008, 12:38 AM
Even if you didn't have the Q-Connector, you could just refer to your manual, the pins are clearly marked.
Old November 6, 2008, 05:26 AM
kav kav is offline
How does that look? Anything obviously wrong?
ImageShack - Hosting :: img2623mediumjn8.jpg
ImageShack - Hosting :: img2624mediumqh6.jpg
Old November 6, 2008, 06:52 AM
JD JD is offline
Originally Posted by kav View Post
The CPU power going over the GPU. You should be able to fit it between the motherboard and the GPU close to the expansion slots of the case. It'll look cleaner but the way you have it isn't wrong per say.
Oh and that Intel stock fan needs to go
