Old November 1, 2008, 09:14 PM
Default New to PC gaming. Requesting help building a rig.
so I've been using an old P4, 756MB DDR1 ram, 64MB video card PC for about 5 years now, and I think it's time for an upgrade. I wanna start fresh so I don't wanna use any old parts from my current PC except the following.
Samsung 216BW 21.6" Monitor@1680x1050 native res.
a year and some odd month old wireless card.
Windows XP Professional retail copy no CD key though :/
I want a PC that will last me 3-4 years. Of course I plan on upgrading within those 4 years but I don't wanna end up replacing all the parts. I want the best GPU out right that last awhile, and a PSU that I won't need to replace unless it's broken. CPU and mobo are something I need help with and an explaintion on what Core i7 and X58 are. this PC is strictly for gaming, surfing, chatting, and some movies. I won't be building for a month since I just got a job and wanna save up. so can someone give an example of the best rig that can max out all games at that native res?
Old November 1, 2008, 10:19 PM
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Old November 1, 2008, 10:26 PM
BALISTX's Avatar
What is your budget? Do you plan on overclocking? You could run either an E8400 Dual Core @ 3.0GHz stock speed or a Quad Core Q9450 @ 2.66GHz
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old November 1, 2008, 10:30 PM
Mostly gaming but also surfing, chatting and watching some movies on the side.
$1500 to $2000...agian I'm building it in a few months but that's how much I wanna spend, budget might increase.
Canada
Whatever will give me the best preformace for the buck.
wireless card.
yes, been looking at these forums for awhile.
depends if it's necessary.
2-3 months.
Old November 1, 2008, 10:32 PM
oh yeah forgot. I wanna max all all games that are out now. Crysis for example I wanna run at my native res with AA and AF at 30fps through out the entire games. I'm all in for that Sli or Crossfire stuff.
Old November 1, 2008, 10:40 PM
Iamcanadian7's Avatar
For a monitor with 1680x1050 you really don't need to invest in SLI or Crossfire. A single high end card will do just fine such as a GTX 280 or a 4870X2.
It's still up in the air as to how much of an improvement Core i7 will be over the current platform. I would wait and see what's what before investing in the new socket.
IMO, you don't really need to be picking parts until a few weeks before your ready to order. Though planning and researching prices as well as making sure the components are compatible is very important. Technology changes so fast that whats good now can be obsolete 3 months from now.
Old November 1, 2008, 10:49 PM
geokilla's Avatar
Hmm, there really isn't much for you to upgrade now that Core i7 is coming out. However, you don't need Core i7 with your use, plus it'll be too expensive. If you wait for Core i7, you MUST go with DDR3 and it'll probably cost over $600 on the CPU, motherboard, and RAM alone.
Even though you have a $1500 to $2000 budget, I like to order things that are the best bang for buck and then go on from there. So here'a reference on what I think you should be able to get for around $1500.
Intel Core 2 E8400/Q6600/Q9450
ASUS P5Q-Pro or Gigabyte EP45-DS3R. You may want to take a look at HC's review on the EP45-UD3P as well.
OCZ Vendetta 2
OCZ, Corsair, Patriot, etc. 4GB DDR800 CL4 RAM
Corair HX620 or TX750
ATI 4850/4870 or NVIDIA 9800GTX / GTX260 216SP
WD/Samsung/Seagate 640GB
Antec 900 or whatever that you like
Mouse, Webcam, Keyboard, Speakers, etc. is user preference.
Purchase from places such as NCIX or Direct Canada. Those are really good places to purchase from. And don't forget to use the price match option.
Old November 1, 2008, 11:02 PM
BALISTX's Avatar
Intel Core 2 Duo E8400 Dual Core Processor LGA775 3.0GHZ Wolfdale 1333FSB 6MB Retail - $189.99
OCZ Vendetta 2 Triple Heatpipe CPU Heatsink AM2 LGA775 S939 S940 S754 120MM Fan 800-1500RPM 20-32DBA -$48.07
Xigmatek ACK-I7751 Crossbow Mounting Kit for 3 Piece Heat Pipe for HDT-S963 HDT-S1283 RS-S1283 - $13.50
Gigabyte EP43-DS3R ATX LGA775 P43 PCI-E16 4PCI SATA2 RAID HD Sound GLAN 1394 Motherboard - $124.99
Diamond Radeon HD 4870 750MHZ 512MB GDDR5 PCI-E 2XDVI Video Card x2 - $599.98
Mushkin XP PC2-8000 Redline 4GB 2X2GB DDR2-1000 CL5-5-5-12 240PIN Dual Channel Memory Kit - $99.99
Western Digital Caviar Black 640GB 7200RPM 32MB Dual Proc 3.5IN SATA Hard Drive OEM 5YR Mfg Warranty - $85.98
LG GH22NS30 Black DVD+RW 22X8X16 DVD-RW 22X6X16 DL 16X/12X 2MB SATA OEM - $27.98
Corsair HX1000W CMPSU-1000HX 1000W ATX 20/24PIN ATX 80A 12V Afc Modular Power Supply W/ 140MM Fan - $289.99
Coolermaster CM 690 Mid Tower Black ATX Case 5X5.25 5X3.5INT No PS Front USB Sound Firewire & eSATA - $97.58
Total Before Taxes and MIR: $1578.05
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old November 1, 2008, 11:09 PM
BALISTX's Avatar
You are welcome. Now keep in mind a lot of those prices are current sales prices. I would check again when you go to order at what prices are and make changes accordingly. Pretty much if I had the amount of a budget on a PC that is what I could get.
P.S. Welcome to HWC.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
