Old November 1, 2008, 11:47 PM
One major problem with that build. That mobo has 2 PCIEx16 slots but the 2nd one only runs at 4x. Two 4870's would be wasted. Spend a little more for a Gigabyte EP45-DS3R or any p45 as they run at 8x when both are in use. I'm not even sure if that wouldnt be a bottleneck, maxbe just one 4870x2 would be better.
ASUS P5Q-E - E8400 (4GHz) - Corsair TX650W - 2xHIS HD 4850 IceQ Turbo - 2x2GB Mushkin Ascent 8000 - 2xWD 500GB - TRUE 120 - Antec 1200 - ASUS Xonar DX - Big Smile
Old November 2, 2008, 12:08 AM
This is what I was thinking about getting.
E8400
Maximus II Formula
Gigabyte or Powercolor 4870X2
Corsair HX1000W
Corsair XMS2 Dominator DDR2-1066 4GB
As for the case, I remember seeing this awesome orange and black Voodoo PC case...anyone know where to get one of those?
Old November 2, 2008, 12:22 AM
BALISTX's Avatar
Voodoo cases are custom made by Lian-Li and are custom painted. What Voodoo rig was it and when did you see it?
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old November 2, 2008, 12:31 AM
actual thread is
http://www.hardwarecanucks.com/forum...e-pics-68.html
Old November 2, 2008, 12:49 AM
BALISTX's Avatar
It's a Lian-Li case but not sure which one. One of the other guys on here might know exactly what case. I know Voodoo doesn't sell their cases even if they are older so you'd have to do some looking.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old November 2, 2008, 04:38 AM
misterlarry's Avatar
Good suggestions geokilla and nice parts list there BALISTX.
Asrock Z68 Extreme3 Gen3 - Intel i5 2550K @ 3.4 GHz - Corsair H80 CPU Cooler- 4x4 GB G.Skill Ares DDR3 1600 - EVGA GTX560 Ti
1x120 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old November 2, 2008, 05:29 AM
Mr. Gruntsworthy's Avatar
I'm thinking that maybe the 1000W psu is overkill, even with future-proofing in mind. A 750 would be better, wouldn't it?
MAIN RIG:
Case: Antec 900
CPU : Intel E8400 45nm Core 2 Duo @ 3GHz 1333MHz FSB
RAM : 4GB DDR2 800MHz (OCZ Platinum)
HDD : Main: 120GB SSD (OCZ) Media: 500GB (WD) Storage: 1TB (WD)
GFX : HD4850 (512MB)
PSU : 610W PC Power Silencer
MoBo: Asus P5Q SE
View : Acer H213H 21.5" @ 1920 x 1080
Oshawa Deathmatch Community -- An open group for Durham/Toronto Airsoft, Paintball, and Nerf players. Come join!
My Game Dev website: http://mikeseguin.webs.com/
Old November 2, 2008, 05:43 AM
Babrbarossa's Avatar
Maybe an antec true power quattro 850- they're much cheaper and pretty good
psst, wanna see my binder?
  #19 (permalink)
Old November 2, 2008, 06:39 AM
geokilla's Avatar
A Corsair HX620 was pulling 791W from the wall when attempting to run 4870X2 in Crossfire mode and it was still working "fine". Just was't providing enough juice to power both 4870X2. However, since you're just going to crossfire 4850 or 4870, the HX620 is good enough. If you want to move it up a notch, then get the TX750.
If you get a modular PSU, it'll make cable management WAY easier.
  #20 (permalink)
Old November 2, 2008, 09:35 AM
cwestwell's Avatar
Geokilla and Ballistx pretty much got a new rig covered...but it is impossible to know what the prices will be like in a few months when you go to build this..
As for your parts suggestions they are all pretty solid but the board is pricey.. once you go to the ROG Asus board your getting into pure Enthusiast boards which are great for liquid cooling and high OC (mostly bragging rights) and with X58 and Core i7 around the conrner buying enthusiast level products is a lot of money for nothing...you should be able to get a Core i7 and X58 boards for around $700 I figure and DDR3 is coming down rapidlly. It just somthing to think about.
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
