Old October 25, 2008, 06:35 AM
BALISTX's Avatar
Default $500 Parts Budget
Need help with some parts regarding my build. I want to be able to play Far Cry 2
Far Cry Recommended System Requirements.
CPU: Intel Core 2 Duo Family, AMD 64 X2 5200+, AMD Phenom or better
RAM: 2GB
GPU: NVidia 8600 GTS or better, ATI X1900 or better
Budget $500.00
Parts Needed:
Motherboard: SLI cable and overclockable. Nothing insane just to go from say 200 FSB to 333 FSB.
Processor: Intel
RAM: at least 2GB
DVD: SATA, Black.
PSU: Can handle SLI and dual core processor, preferbably Corsair. The OCZ PSU's won't reach from the bottom of my case to the top of my case. CM690.
I already have a 9600 GT and will get another in a few months or so.
Heatware
HWBOT
Old October 25, 2008, 07:38 AM
I highly suggest you consider 4GB of ram.
Old October 25, 2008, 08:01 AM
Iamcanadian7's Avatar
This is what I put together off NCIX, I'm sure you could get the price down with a quick pricematch.
Intel E5200 2.5 GHZ -$118.21
Asus P5N-D Board - $170.85
Corsair XMS2 PC2-6400 2X1GB - $54.91 - $41.91 after MIR
LG GH22NS30 Black SATA Burner - $36.57
Corsair VX550W power supply - $111.73 - $91.73 after MIR
Total of $492.97.
If you have the funds available I would bump the ram up to 4GB like the G-Skill 4GB PC2-8000 kit for $89.32.
I assume you don't need a viedocard since you have a 9600GT.
Man, have prices ever gone up lately!
Old October 25, 2008, 08:20 AM
BALISTX's Avatar
Prices have gone up.
Direct Canada has the EVGA Nforce 750I SLI LGA775 - $162.69
I don't think the VX550 will be enough for SLI.
Direct Canada has the TX650 for $88.88 after $20 MIR.
Heatware
HWBOT
Old October 25, 2008, 09:01 AM
BALISTX's Avatar
Here is what I came up with.
Corsair TX650W 650W - $88.88
Corsair TX650W 650W ATX 12V 52A 24PIN ATX Power Supply Active PFC 120MM Fan - DirectCanada
Intel Pentium Dual Core E5200 - $107.67
Intel Pentium Dual Core E5200 Dual Core Processor LGA775 2.5GHZ 800FSB 2MB Retail Box - DirectCanada
EVGA Nforce 750I SLI LGA775 ATX DDR2 2PCI-E16 1PCI-E1 2PCI SATA RAID Sound GBLAN Motherboard - DirectCanada
LG GH22NS30 Black DVD+RW 22X8X16 - $25.99
LG GH22NS30 Black DVD+RW 22X8X16 DVD-RW 22X6X16 DL 16X/12X 2MB SATA OEM - DirectCanada
Mushkin EM PC2-6400 4GB 2X2GB DDR2-800 CL5-5-5-18 - $82.01
Mushkin EM PC2-6400 4GB 2X2GB DDR2-800 CL5-5-5-18 240PIN DIMM Dual Channel Memory Kit - DirectCanada
Total: $467.24
Heatware
HWBOT
Old October 25, 2008, 09:31 AM
MacJunky's Avatar
Pricematch! Canadian Prices: G.Skill - G.SKILL F2-8000CL5D-4GBPQ PC2-8000 4GB 2X2GB DDR2-1000 CL5-5-5-15... - F28000CL5D4GBPQ
When I PMed the same RAM that I linked to I got it for $71.02.
<3 you NCIX.
Old October 25, 2008, 10:19 AM
3.0charlie's Avatar
Sold.
Hydro-Quebec is salivating...
Old October 25, 2008, 10:56 AM
S_G's Avatar
S_G S_G is offline
Depends on the PSU. My EliteXStream 800W does, but my ModXStream 600 does not.
VX550 should be enough for SLI'ed 9600GTs, but yeah, the 650 would be the safer bet.
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
Old October 25, 2008, 11:07 AM
I have an ocz stealthXstream 600w that i payed $80 for 2 months ago, the wires easily reach everything in my antec 900, its a pain having a bottom mounted psu and 2+ sata devices though
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old October 25, 2008, 11:54 AM
BALISTX's Avatar
I had the exact same PSU and the way I went to route my cables for cable management the cables weren't long enough.
Heatware
HWBOT
