Old October 23, 2008, 11:39 PM
Default $1500 first build
I have chosen so far.
I see. ok updated rig.
E8400
P5Q pro
G.skill PC2-8000 DDR2-1000 2x2GB
HIS 4870 DDR3 512MB
Corsair 650W
Antec Three Hundred
Thermalright Bolt thru kit
OCZ Vendetta
Two 120mm blue LED fans
LG DVD Drive
Seagate baracudda 250GB
Artic Cooling MX-2
Windows Vista Home Premium 64BIT OEM
Logitech LX3 Mouse
Logitech Access Keyboard
Total with tax and free shipping - 1,274.88
Total with tax and standard shipping - 1,318.79
I still need a gaming mouse and keyboard, a case(antec 300 maybe?), and a good CPU fan for the cooler, something that goes well with it.
Old October 24, 2008, 01:28 AM
EDIT - Picked out a few other parts.
Antec 120mm Tricool fanx2
Antec Three hundred
Razer Lycosa keyboard
Razer Copperhead Tempet mouse
Noctua ultra quiet cooling fan 120mm for CPU heatsink.
Old October 24, 2008, 03:11 AM
I absolutely HATE anything from Razr. I have never had one product that didnt crap out from daily normal use yet. My Razr head phones, the jack is already getting weak and kicking in and out. THe Razr designed mouse sold by MS, same issue with wiring. What ever happened to the gold old days when only pintos where under engineered? I wound up getting a MS Comfort OPtical Mouse 3000 and I love it. Its very responsive even for Crysis, where its not all aiming, but fast and accurate wrist flicks for suit controls + aiming.
Acer 5920G ( Stock Air ) no OC:P
At least its DX10!
Old October 24, 2008, 04:03 AM
matsta31's Avatar
I guess it is all different form person to person, but I do love my razer mouse.
Everything does look great, but here is a comment:
I dont know if you like the true or not and how much you want to OC but there is a new king of the hill on the CPU heatsink scene, actually there is two : Vendetta2 and sunbeam core contact. Both are cheapr than the true and are great.
Sold hardware again.....
Currently using WHS hardware....
Old October 24, 2008, 04:41 AM
S_G's Avatar
S_G S_G is offline
Go for the Sunbeam Core Contact if you want a better heatsink than the TRUE, it's also cheaper. Go for the Vendetta 2 if you want to save even more cash, it's roughly on par with the TRUE. The Xigmatek HDT-S1283 is also right up there, and the cheapest of the bunch.
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
Old October 24, 2008, 05:15 AM
Dashock's Avatar
I second the Vendetta 2 price vs performance is exxelent and you save some green especially now.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old October 24, 2008, 06:33 AM
I suggest a little bigger PSU if you think you may go Crossfire down the line, if not don't worry about it. Direct Canada has the logitech G11 gaming keyboard on sale right now, not sure if it's cheaper at 55$ than the Razr.
Old October 24, 2008, 07:18 AM
Just like he said.. The HDT-S1284 is pretty good too.. Ima do some research between the the S1284 and Sunbeam CCF (core contact freezer).. wonder which one is better.
Old October 24, 2008, 08:38 AM
CanadaRox's Avatar
Looks like a pretty good rig. The only things I think would be worth changing would be a slightly larger PSU for future upgrades. That one is enough for what you have there, but if you wanted crossfire, it would be a lot more expensive since you'd likely need a new PSU as well. And again, the heatsink isn't worth the high price. You can get better ones for much cheaper. Last thing is getting a larger HDD as they aren't too expensive and having too much space is better than not having enough. Last thing is I'd recommend getting a 4870 from someone other than Diamond. jdrom is currently attempting to get an RMA through Diamond and its not going well at all. No auto reply, the website goes down often and is slow and the "Live Support" is never online. So for a few more bucks I'd personally go with another brand.
Project: Black and White
Old October 24, 2008, 05:54 PM
E8400
P5Q pro
HIS 4870 DDR3 512MB
Corsair 650W
Antec Three Hundred
OCZ Vendetta
LG DVD Drive
Artic Cooling MX-2
Logitech LX3 Mouse
